08-24-2018, 11:01 AM | #1 |
Rep 2,931
Grinding noises after installing X-pipe
I've recently installed the RE X-pipe and is loving the extra volume. However, I'm getting a rubbing noise, almost like 2 things are grinding, intermittently while going on somewhat smooth surfaces. This appeared to only happens after the car is hot. I don't hear anything when going over rough patches. I had tried shaking the exhaust cans themselves and they are solid - no rattles. Other than the heatshield potentially rubbing on the driveshaft (is this even possible), does anyone else have any ideas what else could cause things to rub when installing an X-pipe? Any inputs would greatly be appreciated. Thanks.
08-25-2018, 05:18 PM | #2 |
Rep 2,931
As it turned out, it was a relatively simple fix. The installer used a screw on the x pipe mounting plate that was too long and was hitting the plate or heat shield above it. Swap out for a shorter screw and problem solved...at least I hope problem solved - I haven't heard any noises on the drive home. I love simple fixes
Finnegan711.00 |
08-25-2018, 08:16 PM | #3 |
Rep 3,004
YAY!!!!
So pleased to hear this; it wasn't a RE QC issue....it wasn't a fitment issue....great news.
Racerbruce
08-28-2018, 10:39 AM | #4 |
Rep 12,635
Garage List E86 Z4 M [10.00]
What’s your overall exhaust setup? I just want a little extra grunt out of my factory system but don’t want to introduce drone neither. Was thinking maybe the RE X pipe was the answer...
08-28-2018, 12:06 PM | #5 |
Rep 2,931
Just the RE X-pipe with Eisenmann sport cans. Everything else is bone stock
You know, after looking at the stock x-pipe off the car, you can just have a shop cut that resonator off and replace with a couple of pipes and saves some cash. The stock piece already have the crossover built-in.
08-29-2018, 01:32 PM | #6 | |
Rep 1,130
2014 BMW X5 Sdrive35i F15
08-29-2018, 04:16 PM | #7 |
Rep 2,931
If the OE X pipe has larger diameters, then I couldn't tell. Both OE and RE pipes mate straight up to the OE S pipes without any expansion or necking down. The only thing that I had noticed is that the OE pipes are rectangular/squarish in shape after the resonator.
RossBMWZseries227.00 |
08-30-2018, 01:36 PM | #8 |
Rep 1,771
Drives: 2007 Z4M Coupe
I run RE X-pipe and cans. Personal opinion, if I were to do it again, I would skip the X-pipe. Would def do headers first and foremost and then cans for some extra noise.
08-30-2018, 01:45 PM | #9 |
Rep 2,931
Unfortunately, I live in the Republic state of California - I can't and don't want to touch anything emission related, which means nothing forward of the X-Pipe. Heck, I can't even touch the intake for that matter
At this point, I'm pretty happy with the sound and the car and is pretty much done "modifying" it - famous last words. Although I may consider a suspension refresh sometimes down the road, but that is about it |
09-02-2018, 02:36 PM | #10 | |
639
Rep 3,124
I manage to get away with RE catless S-pipes. I take it somewhere where I know they won't bother looking under the car.
09-02-2018, 07:28 PM | #11 |
Rep 2,931
That had crossed my mind, but I really don't like the off-chance that a different tech would end up checking for it and failing me. At this time, I'm not really itching for a set of catless S-pipes - yet.
09-04-2018, 04:53 PM | #12 | |
Rep 1,130
I'm so tempted to run to my local muffler shop so they can cut out the resonator off the OE X pipe. I wonder if my car would spit out flames with my catless headers, 100 cell race cats in the S pipe, and RPI mufflers
