05-21-2018, 05:06 PM | #1 |
Rep 354
What is the temperature dial between the center vents for?
So above the climate control section near the vents lies another... climate control dial? What is this? I looked in the manual but only found a very vague description of the feature (#3). Does anybody know the function of this dial???
05-21-2018, 05:15 PM | #2 |
Rep 4,857
As indicated in the manual, it changes the temp of air blowing out. For me it is useless and always on blue unless someone touches it when they aren't supposed to touch it. You will get some responses from people who love it but to me it is completely unnecessary.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
05-21-2018, 05:40 PM | #3 | |
Rep 354
05-21-2018, 05:47 PM | #4 |
Rep 97
Its more to fine tune your A/C.
I have never used mine, it is always in the blue side. Like the previous post said some love it and some find it it useless, i find it useless . Sandro |
05-21-2018, 05:49 PM | #5 |
Rep 354
I just don't understand the intent...? If you keep it on cold all the time, does it make the winter heat a little less hot?
05-21-2018, 05:56 PM | #6 | ||
Rep 4,857
05-21-2018, 06:07 PM | #7 | |
Rep 2,575
Germans believe you want to keep your head cooler than your legs (especially in the winter), thus the need to have an ability to adjust the temperature of air blowing towards your head. In the summer, I have it on "max blue/cold". In the winter, I frequently adjust it mid-way towards "red". That is unless I get tired or sleepy, in which case a blast of "blue/cold" air in the face helps to keep one alert. HTH, a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
11
JoeKixxon721.00 pokerface439.50 jmg19121.00 Tyresian69.00 tuco44646.50 Lance_Goodthrust4.50 Paul Blart51.50 tturedraider5517.50 philth365.50 pixelcort45.00 braaaap7.50 |
05-21-2018, 07:21 PM | #8 |
Rep 6,879
I use it all the time to fine tune the temp. I keep the actually temp at 70 and never touch it but I do use the wheel to make it slightly warmer or colder. It's all the way blue in the afternoon when my car has been sitting outside all day and I want it ice cold. It's less than blue and sometimes all the way red in the morning when my car has been sitting overnight in my garage and the temp inside is already cool.
05-21-2018, 08:11 PM | #9 | ||
Rep 354
05-21-2018, 08:33 PM | #10 | |||
Rep 393
Drives: 22 G80 Sao Paulo Yellow
It's for people that wanna keep there body one temperature but not have that same air temp in there face weather it be hot or cold some hate cold air in face others hate hot air in face. For me I like cold/ cold in summer but in the winter the car is set to 70/75 heat but the center dial I like cooler towards face as I hate hot air blowing on my face and in my eyes. |
05-21-2018, 09:21 PM | #11 |
Rep 282
BMW: We gave you a tenth of a degree resolution to adjust the temperature, but we could not get the accuracy down to that level and when occasionally it's 10 degrees off, use the little thingamagingy between the two front vents to deal with that. Hold your breath long enough and we might give you a sync button for the passenger temp. Blowing hot air into the cabin when the engine is hot is free of charge, but if you want ambient air temp, you are kindly advised to open the windows or drive short distances before the engine gets to operational temperature.
05-21-2018, 10:03 PM | #12 |
Rep 116
I think the upper body region is for just the two vents on each side of the dial.
Lance_Goodthrust4.50 tturedraider5517.50 |
05-21-2018, 10:13 PM | #13 |
Rep 207
Per my BMW Genius appt last week: it changes the temp of the air blowing from that vent by +/- 5 degrees. So it you have your climate control set to 70 and you turn it all the way blue, the air from that vent will be approx 65 degrees. All the way red and it will be approx 75 degrees.
No idea if this is BS or not but that’s what I was told. FWIW I just leave it blue and forget about it.
2018 M3 - Tanzanite/Black, DCT, Comp, Exec
pixelcort45.00 |
05-22-2018, 12:12 AM | #14 |
Rep 5,056
My AC is set to Auto, 60 degs, and dial max blue and I never touch anything other than turning everything off when windows are down. I like to keep it simple stupid
05-22-2018, 12:24 AM | #15 |
Rep 3,971
I hate this "feature" and unfortunately it is one of the worst inventions by BMW.
I get in my car yesterday and it is 45 degrees outside. Temp in car set to 72 but blowing cold air. Turn dial to red, cold air stops. Mind you, I just started the car. Get in car later, temp up to 55 degrees outside, but sunny now, car still set to 72 and hot as you know what. Turn to blue. Repeat constantly. Why have digital temp control in car if it does nothing?
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
05-22-2018, 12:28 AM | #16 | |
Rep 5,056
05-22-2018, 05:02 AM | #17 |
Barge driver
8729
Rep 12,521
I understand the intent, I find it very useful, if you're set at 22c on a cold day but you feel "cold" yourself rather than because of the set temp then just move the dial to the red setting for a warming flow of air.
730d/Z4C
pixelcort45.00 |
05-22-2018, 07:22 AM | #18 | ||
The Tanzanian
1362
Rep 1,515
Drives: BMW M3, Audi RS6, Mini Cooper
I do live in Bay Area though so basically it's always in the middle
2023 F56 MINI Cooper SE Midnight Black II on Carbon Black 2021 C8 Audi RS6 Avant Mythos Black on Black/Grey 2016 F80 BMW M3 Black Sapphire Metallic on Silverstone |
pixelcort45.00 |
05-22-2018, 08:54 AM | #19 |
Moderator
7537
Rep 19,368
Google is great!
It knows more about this topic than it does about yanny/laurel or Meghan Markle: https://www.google.com/search?client...mperature+dial |
05-23-2018, 10:22 AM | #21 |
Rep 2,340
I believe (although I'm not 100% certain) that there is a cold feed direct from the filters and air con and a warm feed from the heater and that it allows you to control how much air comes from each. Uses a flapper to close off either channel. End result is fine tuning of the temp.
For me, if cooling I go 100% blue. If heating go 100% red. |
05-23-2018, 10:35 AM | #22 |
Rep 26,159
Love is in the air...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
