04-30-2018, 01:49 AM | #1 |
Rep 133
MSS Flasher cannot read ECU
Hi Guys,
I wanted to find out if anyone else on here had issues trying to read the ECU on their Z4M Coupe. I tried to access my ECU last night so that i can code M Track mode using my brothers Laptop and INPA Cable which we know successfully works on his 2002 E46 M3 as we have coded CSL SMG software and some other features on the M3 but on my MCoupe, I get the following error when trying to read the ECU: "Trouble IDing the ECU" and it just stays there... If anyone has experienced this before or have any pointers/tips/advice that i can try, please let me know... I've also attached a pic of the Error (got it off the net as i didn't take a screen shot when i was trying)
05-02-2018, 04:17 AM | #2 |
Rep 133
Not to worry, Managed to get it to work using NCS...
M TRACK Mode enabled
05-07-2018, 02:40 PM | #4 | |
Rep 133
Now with MTrack mode, it makes the Traction control button 2 stage... Meaning on stage one Mtrack mode is enabled and it displays DTC and then 2nd stage is full traction off with the Triangle warning sign...
05-13-2018, 09:55 PM | #5 |
1654
Rep 4,318
sweet as
have you also tried to disable the DBC? (dynamic brake control) (pre charges the brake when you push it really hard and fast) The function you need to set to not active is BB_RAB found in the MK60 ecu. (not my findings, but Tom K's from over the pond) Havent done it yet, but looking at doing both of these, although ive been fine with Traction OFF as it doesn't rain here. Track mode with rain looks like an awesome add-on.
Powered by |
05-15-2018, 06:01 AM | #6 | |
Rep 133
No sir not yet... but it made alot of sense when i was on the Kart track, because the entire thing is 1.22km's long, you on the brakes HARD every few seconds... thats where i noticed the DBC becoming intrusive. thanks for the details, i'll look into getting it done.. I've also been ok with traction fully off, just have to be quick to catch it gets the blood pumping But I gave M-Track a bash because it cost me nothing and the car was already charging at the time... its a nice to have Mtrack if you want to mess around in the wet or even on a dry track as some have said in online reviews that its handy when the rear steps out and the revs fly into limiter because thats when the car actually starts loosing forward momentum due to the wheels are just spinning, Now DTC(Mtrack) will not kill the power and slow you down like normal traction control will, it will allow you to hold the revs and be quick about it before stepping in (I've experienced this too) .. so it seemed like a bonus, I'll try it out properly next month at gymkhana against full traction off and see whats what... rainy season is over for us now.. winter is coming
06-03-2018, 06:03 AM | #7 |
Rep 45
Unfortunately as you've found out both mss flasher and martyn's superb ecuworx tool mss5x binary mod will not work with our ecu (mss60) as they are for programming the e46m3 ecu (mss52,54,54hp).
https://www.ecuworx.co.uk/how-to/usi...fication-tool/ I spoke with martyn a couple of years back as to whether he could do this for our ecus and he said yes but not yet. It has some great features like being able to draw in your own throttle sensitivity curve, something which I myself would love. Thanks to your post I have just looked at his site again it seems he has now done this for e9x m3 which has a very similar ecu. I will get in contact with him and report back As an aside be aware that our 'm-track' mode uses the rear brakes heavily (I'm not sure of it does on the e46 version or not), I almost killed a new set of rears at a very wet day at Spa a few weeks ago.
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, RPI, AP f&r w/RSL-29, Apex ARC-8, A048, KW CS, Turner arms & RTAB limiters, VT engine mounts, Rogue pulleys & RSMs, Tillett B6s, custom half cage, UUC ssk, M5 knob, oem strutbrace
06-03-2018, 09:05 AM | #8 | |
Rep 133
Thanks for the heads up regarding Mtrack and the rear brakes, it'll be on my radar..
06-05-2018, 05:40 PM | #9 |
Rep 45
Cool, well I've spoken with him and news seems positive, ish. First it was my bad and we actually use MSS70 (so M5/6 V10 era) ecu, not the MSS60, it's been a while since I've been through this! Good news is someone has sent him a spare one and he has been tinkering.
He's asked me for what features I would like, for me it's drawing the throttle curve, and I would also like to limit revs in all gears to 3k (valet mode type thing, as occasionally I need people to move the car), it's possible to set an individual rev limit for each gear if you like. Anyway, take a look at what can be done on their website and let me know what is of use to you and I will include it on the feature requests. Hopefully we can get some traction on this
06-06-2018, 09:50 AM | #10 | |
Rep 133
Setting the throttle curve is a great feature, can allows us to also smooth out Sport memory as my accelerator pedal is like an ON/OFF switch when sport is on... I'm keen on these ECUworx Features as i want to remove the catalytic converters and the secondary air pump: - Disable secondary air pump - Disable fault code / check engine light for physical removal of the secondary air pump - Disable fault codes / check engine light for cat deletes - Disable CAT Protection (Disables Enrichment) - Shift Lights - Enable Alpha N (for later on ) - Final Drive ratio adjustments (for those who change diff ratios )
06-06-2018, 02:12 PM | #11 |
Rep 45
Fine, yep I'm looking to do the sap delete also so I will test that when he sends me his spare kess v2 to try I would imagine the cat delete option shouldn't be an issue either.
Agree, the sport throttle map is a joke so I want to look into altering both. The standard mode I find ok, I would just like it a little more linear than it is now. I'll let you know how I go, hopefully we can get a tool done soon.
06-07-2018, 12:16 PM | #12 |
Rep 133
Thank you kind sir...
All the best, let us know how it goes with the SAP.
02-09-2021, 03:39 AM | #13 |
Rep 133
MOTKits been ages buddy, so i wanted to know if you were able to disable SAP and the CAT enrichment process on Your Z4m? or made any progress with ECUWORX?
I have purchased a Turner CSL airbox, So now busy looking for a Aplha N tuner that can assist with SAP delete and disable Enrichment process as well. Evolve say they dont do it so i'm currently chatting to Josh at SevernTuning to see if he can assist.
02-09-2021, 02:36 PM | #15 | |
Rep 2,715
Won't be disappointed.
