08-24-2017, 12:27 PM | #1 |
Rep 272
S54 Catastrophic Failure
Hey fellas,
After four previous S54 powered cars, my luck ran out with what I thought would be my most robust one yet - 2007 Z4M Coupe. Street driven, 42k miles, 3-5k oil change/15k valve adjustment intervals documented since new. Most recent oil change and valve adjustment was 1,400 miles prior to this mishap... After previously driving spiritedly (though no overrev, money-shift, etc...), my motor began knocking in 4th gear at 2k RPM. My initial thought was a rod bearing very prematurely spun as it was a consistent "slap" and the typical go-to S54 issue, but that surprisingly was not the case --- After dropping the front subframe, removing the oil pan, inspecting the rod bearings, main bearings, and crank, I pulled the valve cover and plugs where I took a borescope down cylinder #2 and found that the top of the piston was polished clean from hitting the cylinder head. I have not yet been able to determine why, though I did NOT spin a bearing. I'm going back under to see if there is play in the rod, if a wrist pin bushing broke, etc. Regardless, the piston is slapping. This leaves me with essentially four options - 1.) Rebuild at my trusted local shop and have the machine work done at a nearby reputable machinist. This would consist of OEM, CP pistons, Carillo rods, and Schrick cams, etc... $14k 2.) Source a used S54 for $4-5k, spend $$$ on Beisan VANOS, bearings, cams, and airbox for a total of roughly $10k.. all while hoping lightning doesn't strike twice in the same place. 3.) Buy a BMW crate motor for $15k. 4.) Have Lang Racing build me a mildly modified motor (CP pistons, carillo rods, Beisan VANOS, 288/280 cams, DLC rockers, widened rod journals, etc, etc). 5.) Dinan. $$$$$$, but Dinan. Keep in mind this is a low mileage, otherwise mint Z4M Coupe that I now plan to keep for at minimum a few years Are there any options I'm overlooking? Thoughts? Last edited by Eson; 03-05-2018 at 10:10 PM.. |
08-24-2017, 01:46 PM | #4 |
Rep 12,310
Ouch, all those numbers hurt. Didn't you just get this M Coupe not too long ago (I also follow m3f).
Sorry to hear about the troubles. I'm at 92k miles so it's time high time to do some preventative maintenance.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-24-2017, 01:59 PM | #5 |
10855
Rep 4,893
I'm very curious what finally caused it.
As for the options, I certainly wouldnt rebuild this motor/use this block unless you've 100% identified the cause (and all potential damage of it) of the failure and you're sure you can correct it.
NickyC17484.50 |
08-24-2017, 05:01 PM | #7 |
Rep 10,663
Wow, so sorry to hear this and of course the nightmare scenario for any Z4M owner. My personal opinion is to go with #4 if you have the time to spare/extra car to use etc. I'd consider #3 if it came with a warranty from BMW, which I think it does (2 years right?).
I'm very curious to hear what caused this, as it doesn't sound like any of the known traditional issues the S54 can have? Best of luck to you, and believe me my heart goes out to you on this. |
08-24-2017, 08:02 PM | #9 |
salty cowboys fan
6158
Rep 3,407
Yikes. Sorry man.
I'd probably go with #2. Odds of this happening again are pretty low I imagine. Might be able to save some of the upgrades (beisan, etc) from your dearly departed if you already have them.
she’s home! '22 M4 Comp xDrive
08-25-2017, 04:08 PM | #10 |
Rep 335
I'd probably buy a used low mileage S54 and just drop it in. You could do that 3 times before you reach the cost of replacement. Then modify the used motor. Perhaps a supercharger if you want more power.
08-25-2017, 08:00 PM | #11 |
Rep 484
#2 without the cams and air box would be your most economical solution for now.
I'm not a big believer in the more frequent oil changes = longer engine life. It all depends on what ultimately fails. In your case it sounds at this point not to be lubrication related. Likely a fluke. Pick up the dice and throw them again... |
08-31-2017, 03:40 PM | #13 |
Rep 264
#4 or......LS3. With a new crate engine, trans, tune, and other stuff to make it work you are probably near the $14-$15k mark
(sacrilegious I know, but tempting)
2017 M2 - Camber Hubs, MPE, and some other goodies 2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s 2004 Z4 3.0i - Gone, but not forgotten! |
09-08-2017, 11:09 AM | #15 |
Rep 272
Thank you all for the input - I appreciate it!
I've decided to have Dinan (SD Autotech) build me a motor. 11.7:1 CP, 3.3L, forged internals, Carillo rods, 288/280 Schrick cams, DLC rockers, etc, etc.. Will update! |
09-08-2017, 12:34 PM | #16 | |
Rep 10,663
Did you ever find out what caused the failure? |
09-19-2017, 02:28 PM | #18 |
The Slip Angle
31
Rep 50
Drives: 2007 BMW Z4 ///M Coupe
Garage List 2005 Honda S2000 [0.00]
2006 Mazda RX-8 Shinka [0.00] 1994 Mazda Spec Miata [0.00] 2003 Honda S2000 [0.00] 1991 Mazda Miata [0.00] 1999 Mazda Miata [0.00] 1993 Mazda RX-7 [0.00] 1993 Mazda RX-7 [0.00] 2007 BMW Z4 M Coupe [0.00] |
Any updates on this? I am curious to know the root of the failure as well.
2007 BMW Z4 ///M Coupe | 1993 Mazda RX-7 Turbocharged 417 whp | 1999 Mazda Miata All Motor 185 whp | 1991 Mazda Miata N/A 13b PPort | 2003 Honda S2000 All Motor 238 whp | 2006 Mazda RX-8 | 1998 Lexus LX470 | www.instagram.com/garagequinnmotors
09-19-2017, 04:45 PM | #19 | |
Rep 272
As time permits, I'll go into more depth with a writeup. Last edited by Eson; 09-19-2017 at 04:54 PM.. |
09-19-2017, 05:16 PM | #20 |
10855
Rep 4,893
So then how made that slap the piston agains the cilinderhead?
09-19-2017, 07:24 PM | #21 | |
Rep 10,663
09-19-2017, 07:51 PM | #22 |
636
Rep 3,124
It didn't. It was hammering the piece of steel between the piston and head.
I had a similar fate befall my '73 Sports Bug when a piece of the Cal Custom air cleaner fell down the intake.
