      01-12-2017, 11:16 AM   #1
the fly
Drives: '95 M3
new OE Z4M FCABs / LCABs – pre-pressed front control arm bushings for z4 and e46
USD 119.00
Pair of new Z4M front control arm bushings (FCABs) already pressed in to good used lollipops. These are the 66mm dia bushings and lollipops for the Z4M (part #31107836862) but folks also use these as an upgrade mod for non-M Z4 and e46 models. They do this because of the firmer rubber bushing design (less voids, not fluid filled) and also because the offset bushing provides additional steering caster angle versus the centered stock units for non-M models. See here for an explanation:
http://www.e46fanatics.com/forum/sho....php?t=1062954
http://forum.e46fanatics.com/showthr...ffset+bushings
These are ready to slip on to your control arms and bolt on to tighten up your front end handling. No messing around with DIY swearing at improvised bushing pressing or borrowing your friend’s car and asking a machine shop to press out/in the bushings while your car is jacked up.
Selling for $119 shipped. Once complete, you send back your old lollipops to me (in good shape). Just for reference, that’s a good bit cheaper than the $160 that online retailers charge for pre-pressed Z4M bushings.
If you check these links, I have been doing this popular service on the BMW forums for several years and have 100% feedback.
http://www.m3forum.net/m3forum/showthread.php?t=376064
http://forum.e46fanatics.com/showthr...825&highlight=
http://www.bimmerforums.com/forum/sh...shings-for-e36
      01-14-2017, 05:48 AM   #2
wdb
dances with roads
wdb's Avatar
4732
Links no work.
      01-14-2017, 07:54 AM   #3
the fly
Drives: '95 M3
Hmm...
Try googling "the fly" and "pre-pressed fcabs" and you'll find my other threads and info.
      09-27-2017, 07:44 PM   #4
the fly
Drives: '95 M3
Bump!
      09-27-2017, 08:06 PM   #5
Boosted 1
Where Does He Get Those Wonderful Toys?
Boosted 1's Avatar
Drives: 07 M coupe, Gx470, M2 PE
Ill let you know, thanks for the quick pm's
      01-23-2018, 06:27 PM   #6
the fly
Drives: '95 M3
Bump! Back in stock...
      03-01-2018, 09:52 PM   #7
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Just replaced my 75,000 fcabs with these. Got mine with two day shipping and a paper with some tips to remove/replace them. I ended up using a hammer and a 2x4 though. That always seems to work for me!
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      03-02-2018, 02:44 PM   #8
wdb
dances with roads
wdb's Avatar
4732
Do you notice a difference?
      03-02-2018, 04:40 PM   #9
bignosejim
bignosejim's Avatar
Haven't had a chance to drive it yet. I'm in the middle of installing FA 500 coilovers and SDW rtabs also. There was no indication of cracks, but the rubber seemed a bit softer than the new ones I put in. I might not be able to tell any changes specifically to the fcabs because of the other work I'm doing to it.
wdb4732.00
      03-11-2018, 07:13 AM   #10
the fly
Drives: '95 M3
I should have another set available next weekend if anyone is interested...
      03-11-2018, 09:20 AM   #11
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
I need to replace my FCABs when I do my rod bearings. I've developed some shimmy in my steering wheel, and I'm at 50K+ on my original FCABs. I'll let you know in a couple of weeks. How quickly do we need to return the "cores"?
Salty
      03-11-2018, 09:44 AM   #12
the fly
Drives: '95 M3
Salty
A couple of months.
      03-16-2018, 08:52 PM   #13
the fly
Drives: '95 M3
Back in stock...
      03-27-2018, 04:35 PM   #14
Boosted 1
Boosted 1's Avatar
Bump for a great guy and great product! These FCAB saved me a lot of swearing. Got the old ones off and new ones on in under 10min
      04-23-2018, 01:34 PM   #15
the fly
Drives: '95 M3
Thanks Ches!
Back in stock...
      05-14-2018, 09:03 AM   #16
the fly
Drives: '95 M3
bump!
      06-01-2018, 08:43 AM   #17
the fly
Drives: '95 M3
bump!
      07-10-2018, 01:48 PM   #18
the fly
Drives: '95 M3
back in stock!
      08-12-2018, 02:08 AM   #19
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
bump.
just used Rick's service to replace my FCABs, highly reccomended. just unbolt your existing FCABs, bolt on the replacements, and you're good to go. much faster than having to screw around pressing bushings in and out.
considering the cost of the replacement bushings alone, this service is nearly free, so its really a no brainer.
      08-28-2018, 09:27 AM   #20
the fly
Drives: '95 M3
Originally Posted by jdoublehcubed View Post
bump.
Thanks for the kind words. Back in stock...
      09-18-2018, 11:18 AM   #21
the fly
Drives: '95 M3
bump...
      09-18-2018, 11:36 AM   #22
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Baaah, just bought news one for our E46. If I would have had my eyes open a bit wider and saw this...........
