01-07-2017, 11:10 PM | #1 |
Rep 136
How Low Can You Go?
I just finished installing a new lip on my bumper and now it only clears 2.75" LOL. For reference, I can just barely clear the e9x key fob... What's everyones ride heights? I'm scared to drive mine now, can I even roam around the city without avoiding all speed bumps?
01-07-2017, 11:36 PM | #2 |
Rep 10,682
How long do you want it to last? Keep the ride height stock and avoid any big dips or bumps and you might have a chance. Or keep it parked in your garage and dont drive it. You just want it to look cool. It does not actually have to be driveable.
01-08-2017, 12:41 AM | #4 |
Save the manuals!
6035
Rep 6,754
Meh. I've seen and driven lower. Adapt your driving style or buy replacement lips.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
01-08-2017, 03:29 AM | #6 | |
Rep 7,139
Thanks! |
01-08-2017, 08:06 AM | #8 |
Rep 7,139
01-08-2017, 08:49 AM | #10 |
Rep 371
If you're using it as a snow plow, I'd say it's not low enough.
01-08-2017, 03:48 PM | #16 |
Rep 136
01-08-2017, 04:02 PM | #17 |
Rep 1,044
I'd say it's roughly the same as yours. I have my driving height to a little lower than OEM (maybe two inches lower all around?)...
I've had no issues with scraping. Then again, I DO have a setting to raise the front up significantly which I've had to use often...hahaha...but, I live on Long Island and our roads suck. I didn't realize you have the 1M bumper and that lip...that will be similar to my set up soon...I like how low it sits. Just a suggestion...maybe you should do air
I did a lot of things to it. |
01-08-2017, 10:02 PM | #18 |
Rep 536
You should be able to get away with clearance if you're running 19" wheels and up?
I had a lip extension with a 1.0"(F) drop, but on 18" wheels. It was setting at half of the key fob, and ripped to pieces from trying to exit my bank parking lot. Lol, epic fail But good thing that the actual lip didn't take any damage. Just be sure to angle it on all bumps & dips! And you should be fine |
01-09-2017, 01:27 PM | #19 | |
Rep 136
01-09-2017, 06:20 PM | #20 | ||
Rep 536
I still ended up losing But what I learned from it? Was not to take that exit anymore |
