12-27-2016, 12:14 AM | #1 |
Rep 181
How much body roll?
*if this is better suited for the technical forum, please move*
Getting on / off highway ramps with EDC set to Sport (2 lights on, and I have ZCP), I can feel the body roll if I'm going a bit fast. My question is, how much body roll do you feel in the car's stock form? It's such a subjective question, and it depends on a lot of factors, I understand. I've searched, but most threads about body roll have been about body roll complaints, or what upgrades have reduced roll. Much fewer discussions have happened regarding how much body roll there is in the M3, and I think it'd be helpful to hear what others are / have been experiencing. Or, if you know of helpful links out there, please point them out. Thank you! |
12-27-2016, 03:30 AM | #3 |
Rep 7,139
Hey Young,
tricky question to obtain comparable answers to I guess but still interesting. What about differences in body roll between the EDC settings, do you notice them as significant? |
12-27-2016, 06:25 AM | #4 |
Rep 3,141
Drives: 2014 M5 6MT
Body roll can be very beneficial to grip. If the chassis is too stiff and you dont have the right tire, you will reduce grip. Too much roll can have negative consequences as well. I find that EDC on sport with H&R springs controls my car well, with maybe a mild sway bar upgrade to make it perfect for my driving style.
The general rule is, the stiffer the suspension, the stickier the tire.
2014 M5 6MT
jaehshim492.00 |
12-27-2016, 12:18 PM | #5 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
I don't notice much body roll at all in the sport setting. My car stays pretty flat in hard cornering.
12-27-2016, 04:43 PM | #6 | |
Rep 1,374
and just to add one more, the more sticker tire, you better have good brakes to match them tires on straight + hard cornering
Solo_M_Tech1687.50 |
12-27-2016, 07:41 PM | #8 |
Rep 3,141
Drives: 2014 M5 6MT
Bump stops are used to increase the total spring rate under hard compression... They are not there to stop or limit suspension travel.
2014 M5 6MT
