12-16-2016, 12:01 PM | #1 |
Rep 328
TPMS fails to initialize
It's been below freezing here in Vancouver and I suddenly got a TPMS failure while driving. I don't think it's a pressure issue as I just inflated my tires and they look correctly inflated. In the vehicle status it lists it as TPM malfunction. Is this an issue with the receiver in the car or perhaps did one of my sensors fail? The ones I'm using are aftermarket as they are on my winter wheel set. I've seen this intermittent failure pop up before. But this time it's not going away. Anyone else experience this? Is it just a sensor issue?
12-16-2016, 06:47 PM | #2 | |
Rep 488
Drives: 2011 E90 M3 6MT
12-16-2016, 07:10 PM | #3 |
Rep 328
ah ok. So long as it's the sensor and not the car. I will have to borrow my friends iCarly cable and find out which wheel. is there documentation on doing this with iCarly?
12-17-2016, 06:20 AM | #4 |
Rep 86
Go to a tire repair shop that can use a wireless scan tool next to the tire to check all the sensors and can tell you which one is bad.
Be a Hero to your family 1st, Then the world !
12-18-2016, 02:24 PM | #5 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Take your car to a good tire store. Have them scan your wheels with their TPMS tool. It gives status and battery level. No sense in replacing just 1 if the others are going to die soon. It is not your RDC module or the antenna.....it's one or more of the wheel sensors.
12-23-2016, 06:36 AM | #7 |
Rep 336
I was under the impression that Canadian cars did not use tpms sensors within the tire and used the abs sensors to detect flats by the relative speed differences between wheels. Maybe it might be something to do with that.
01-24-2017, 03:06 AM | #8 |
Rep 328
The error mysterious went away on its own and then came back for a bit and disappeared yet again. I'll have to wait until I get my stock rims back on to see if I need to replace the module. I'm pretty sure in all the times before when i got a TPMS failure, it was always with the none stock sensors.
01-29-2017, 11:49 PM | #9 | |
Save the manuals!
6035
Rep 6,754
Your car has a FTM system. Set the pressures correctly to all four tires and reset the FTM monitor.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
03-27-2017, 09:59 AM | #11 |
David
17
Rep 83
I purchased my car 2 weeks ago and I am also having this message. I assumed the dealership had all these taken care of before having it driven off the lot. So I called my salesman and he pretty much said it was all put on and working correctly before leaving the dealership. Not sure if I should call back and argue with him.
It started to show this message a week after I got the car and then it went away. Then this weekend it showed up again, so I'm not sure what I am suppose to do in this situation. Can I still have the dealer be liable for it and have them fix it? I bought it used so anyone in the BMW used car dealership guys can chime in on this one and let me know, I would really appreciate it. Thanks guys. |
03-27-2017, 10:14 AM | #12 | |
Rep 86
Hopefully, that fixes my issue - probably the same for you. If you go to the tire store and "borrow" their tool and technician for 30 seconds, you'll immediately find out which sensor it is. Then you don't need to buy a tool. I just wanted it for my own toolbox. Now when I rotate tires on the wife's car I can reset the TPMS wheel positions with the tool. Now if only I could code the M3's TPMS to display actual pressures and temperatures of each wheel on the iDrive (like it was on my 2011 550i F10). But that's a different thread and I'm told it can't be done. |
03-27-2017, 10:23 AM | #13 | |
David
17
Rep 83
