08-06-2016, 10:34 AM | #1 |
Rep 350
Stoptech advice needed
I have a line on front and rear stop techs for $2200. Would you do it? They look ok visually but not sure if they may need to be rebuilt.
08-06-2016, 04:55 PM | #2 |
Rep 11,667
Not enough information...
How many miles on them, what are the rotors like. What is the condition of the piston seals Etc.
DEG70.00 |
08-06-2016, 06:03 PM | #3 |
Rep 350
All I know is it's a st40 355 kit. There is a pic of the calipers and rotors and they look ok. But it isn't a high red pic. I do not know how long they were on the car. Another forum member mention to get the rotor thickness measurement. Because replacing the rotors could be a significant cost.
08-08-2016, 06:23 PM | #4 |
Rep 350
Ok so the plot thickens. I received rotor measurements. Two of the rotors are 50% worn the other two are 75% (assuming fronts). Assuming the calipers and pads are good, would you do it? This would be street use, not sure when I would expect to replace the rotors? I guess if the rotors are the same size I could move the fronts to the rear to get more life. I would guess I put 500 miles on a year.
08-08-2016, 07:57 PM | #5 |
Rep 11,667
Did you get actual measurements?
Are the percentages accurate? If they represent percent of usable disc (Max - min) then you should be OK with the low miles that you do. To swap f/r you would have the dismantle the ring from the rotor hat. The rears are different hats/hub with the parking brake. That assumes that the rings are the same part. (Im not sure if they are or not)
08-09-2016, 12:34 PM | #6 |
Rep 500
^What he said.
IMHO, unless the seller is really disclosing the details and forthcoming with the information in a manner that they sound like they know what they are talking about and understand how buying used things work, be skeptical and very careful. |
08-10-2016, 10:28 PM | #7 |
Rep 1,483
I'd be interested in the rears if you don't pick them up.
- Instagram ->@e91kiter |
