04-06-2016, 04:55 PM | #1 |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Understanding BMW's Poor Performance In the New IIHS Headlight Tests
Featured on BIMMERPOST.com 2-Series - HID - Halogen 3-Series - LED - Halogen They also tested with and without adaptive and high-beam-assist, where available. You can see detailed test results on the respective vehicle test pages; just click on "headlights" in the menu. BMW 2-Series BMW 3-Series The best performer (by their rating system) was the Toyota Prius. I'm using this as the reference point. There are some great charts on the IIHS site. The method used to build these charts was to use light meters to measure the amount of light produced by the car's headlights at a given distance. The low-end threshold (where the bar stops) they chose was 5 lux, which is roughly full moon light level. They performed the measurement just a few inches off the ground. On to some charts. On the charts, the blue filled area represents the reach of the low beams, while the grey represents the high-beam reach: LOW BEAMS HIGH BEAMS 3-Series halogen The halogens suck. Plain and simple. Everyone knows this though. With the IIHS reporting on headlight safety, I think the halogen headlamp's days are numbered. 3-Series LED adaptive This is where things get interesting. If you look at the gray bars, you can see that the LED adaptive headlights actually outperform the "best in test" Prius, and by a good margin in some cases. The problem is that the low-beams are abysmal. Clearly the intensity of the lighting is plenty to light up the road, but the aiming of the low-beam setting severely limits reach. This lack of low-beam performance is called out specifically in the IIHS remarks as to why the 3-Series LED equipped models got a low rating. Prius LED (for reference) Hopefully this helps explain why BMW got dinged so hard in the new headlight test. It should also explain why everyone is so confused by the rating. The LED lights are very bright, but the low-beam setting is aimed such that the light is directed at the ground in front of the car, not down the road where you need to see.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
04-06-2016, 05:00 PM | #2 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Thanks. Great info
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
04-06-2016, 05:30 PM | #3 |
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
This is actually a lot better than the other thread I read on the same subject.
Thanks for breaking it down the way you did.....very digestible. Winner or not.....I still wouldn't be caught DEAD in a F-ing Prius (even at night with the better LEDs ), I don't even like to ride as a PAX in my friend's.
AIRPOWER
04-06-2016, 06:37 PM | #4 |
In The Rain
8604
Rep 6,472
Drives: '24 GT4RS, '24 Macan GTS
And that is why Lups hates BMW's LED.
Mommy knows best apparently.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
04-06-2016, 07:40 PM | #5 |
12620
Rep 5,278
I dont understand. For me personally I'd rather have better low beam performance than good high beam performance.
I rarely use high beam. The roads around here are way to crowded to use those (maybe except in the middle of the night). High beam performance for me is hardly important and almost always enough in the rare case I can use them. So then the test verdict is imho right if the low beam performance is sub standard. BMW should fix that.
04-06-2016, 07:57 PM | #6 | ||
11832
Rep 15,400
Who would've thought someone on a bmw forum would be offended by that.
04-07-2016, 07:58 AM | #7 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
I made this thread because a lot of folks in the other thread believed that the "problem" was only with the halogens. They just dismissed the test with comments like, "Oh sure the halogens suck, we all know that." The truth is that all US market BMW headlight options have issues. Obviously the IIHS didn't test the new laser headlights, because our luddite regulations won't allow them here. I did try to write it objectively and explain the facts though, so it may have come off as defensive. Some people will read this and say, "It's ok because the high-beam performance is fine." Like you, I'd disagree with them. The lights are bright enough, but BMW needs to address the way they aim their headlights from the factory.
04-07-2016, 09:13 AM | #8 |
Rep 4,163
Great post.
This is why I re-aim the headlights first thing once I take delivery. I even did this on my 335is and it made a huge difference. I plan to do the same with the F80 if it seems to have the same problem. |
04-07-2016, 10:39 AM | #9 |
Brit Abroad
392
Rep 707
Drives: 2016 Frozen Black M4
Fancy posting a DIY? lol
2016 ///M4 / Frozen Black Metallic / Full Sakhir Orange Leather
Instagram @M4TTE_BMW More info and photos here. |
04-07-2016, 11:11 AM | #11 |
Christmas Poo
1529
Rep 1,378
+1...I pointed both of my LED headlights up...made projection down the road better, not great, but better. Although the high beams are probably the brightest I've ever seen on any car...
Drive the Manual - 2024 G87 - Mr. Hankey's M2 Build Thread
04-07-2016, 11:32 AM | #12 |
Rep 4,163
Haven't done it on an F80 yet as mine is still being built, but on most cars it's a worm drive gear with a phillips head (basically just looks like a bolt) on the backside of the headlight assembly. There's usually two per bulb, so you have to be sure you are not changing the left-to-right sweep.
I aim the headlights on a flat surface having parked the car on a flat surface and move up both gradually until I get a setting I like on a test drive. Just make sure the horizontal lowbeam cutoff matches left to right and you are golden. |
04-07-2016, 03:33 PM | #13 | |
Christmas Poo
1529
Rep 1,378
04-11-2016, 10:43 AM | #16 | |
Rep 91
04-11-2016, 10:52 AM | #17 |
Rep 696
And for anyone who drives primarily in a urban environment this makes little difference. I honestly have yet to see any issue with the standard headlights. YMMV.
04-11-2016, 11:07 AM | #18 |
Rep 814
Hopefully BMW can simply program the vertical slightly higher????
"The people getting the best out of the F30 are the 320 Sport package people" - Jamesons Viggen
04-11-2016, 11:12 AM | #19 |
Rep 100
BMW vs. Prius headlights
Excellent information. Thank you for sharing.
The question is if the Prius headlights have the same sharp cutoff which are common in German headlights? This has a huge impact on low beam performance at distance. Perhaps this was mentioned elsewhere in the IIHS data, but I am guessing that the Prius also puts more light in the eyes of oncoming drivers. |
04-11-2016, 11:17 AM | #20 |
Rep 20,745
Drives: 2021 911 turbo
Thanks a lot for posting this.
Is it possible that the poor LED low beam performance is simply related to their programming to meet US regulation (not allowed to have intensity varying headlights)? After I programmed the EU VLD on my M4, I found the low beam performance to be greatly enhanced. Actually, even the high beams improved even if I don't have NGHB.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
