      03-31-2016, 06:03 PM   #1
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
DKF Hanger to the Rescue
I got a great deal on a Stromung exhaust from a forum member, and I have loved the pops and gurgles and the sound, but I was getting some loud drone under initial heavy load just below 3K RPM, and then when in 5th and 6th under light load, I would get a light drone. Having read that sometimes loosening the stock nuts/bolts helped with drone, I tried to loosen the OEM hanger bolts and was shocked how tightly they had been torqued down. I couldn't budge them with a wrench (spanner), and it took some real torque with a longer ratchet to break them free. I also noticed the bolt on the stock hanger was twisted to one side and was twisting the rubber of the OEM mount.
I had previously bought some DKF hangers from another forum member, and since the stock hangers were being stressed, I decided to try to tackle it without a lift. I didn't even jack up the car. It's tight, but do-able. I installed the DKF hangers with the heavier-duty isolators and was sure not to over-tighten any of the nuts. After a bit of swearing, it was done.
It was starting to rain, so I didn't go far, but initial impressions are a HUGE improvement. Virtually all drone has been removed. Woohoo!!
Salty
      03-31-2016, 06:34 PM   #2
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Cool! Thanks for sharing.
      03-31-2016, 06:44 PM   #3
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I was wondering how stromung would hold up with some DKF hangars. I think there are a couple like set ups out there, but that gives me hope for a no drone and good sounding solution!
◙ Shane
      04-01-2016, 08:06 AM   #4
Mirko
Mirko's Avatar
I don't think it made any substantial change in my setup regarding drone. I might've over tightened the bolt though. I found the drone was usually the worst on really cold days or when it was raining outside. Haven't driven car in either conditions in a long time now.
      04-01-2016, 06:00 PM   #5
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
Granted I have only had the /M for 6000 miles, but I find almost zero drone/rasp on the Stromung setup which I bought new. I previously ran the RPI noise cannons and that was headache inducing in the 2200-4000 rpm range.
      04-02-2016, 07:43 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FWIW, I added a rubber isolator between the OE hanger and chassis and It helped somewhat.
      04-02-2016, 08:04 AM   #7
SaltyNC
SaltyNC's Avatar
370
The original vibration isolators were prone to tearing, especially if over-tightened, but the new beefier isolators from Grainger work well. Grainer also sells the isolating washers. They are actually sealing washers with silicon on the back.
I think the main issue with my OEM hanger installation was that in an attempt to get the tips aligned, the guy that installed mine put the OEM hangers in a bound/twisted position, and everything was torqued down very tight, and that was allowing some of the vibration to transfer to the body. Well, that's the theory, anyway.
Salty
      04-02-2016, 08:06 AM   #8
SaltyNC
SaltyNC's Avatar
370
Mirko, rainy/foggy weather made it worse on my car, as well. I wonder if it is an atmospheric pressure thing.
Salty
      04-02-2016, 10:42 AM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Salty
Yeah, it sounds like the bigger isolators on the DKF are the ticket.
I sold my DKFs before I had a chance to try the better isolators.
I also sold my RPI, so drone was no longer a problem
DKF are definitely nice for adjustment because you can get the isolator in a near no load position.
For OE I find it easiest to fasten the hanger first then adjust the tips.
With the donut clamp snug, I use a floor Jack to raise the tips to the right height and use a rubber hammer to whack the donut clamp side to side for adjustment.
Then finish tightening the donut clamp.
      04-02-2016, 01:56 PM   #10
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Salty
I do the same. It's the easiest method I found for this.
      04-02-2016, 09:06 PM   #11
SaltyNC
SaltyNC's Avatar
370
For the first muffler, I took it completely off to add the DKF hanger. The second one, I removed the bolts from the flange clamp on the x-pipe, then dropped the OEM hanger that the DKF replaces. That allowed the muffler to angle down enough to mount the new DKF hanger. I then realized I needed to cut off the welded nut on the Stromung, so I whipped out an angle grinder with a cutting wheel and did that under the car. I was doing all of this in my garage without a lift and without the car even being on jacks or ramps. Nothing blew up.
Salty
