02-17-2016, 02:30 PM | #1 |
Rep 588
Drives: 2007 Z4M Coupe
DIY Request: Valve Cover Gasket s54
Does anyone have the TIS or a DIY for changing out the valve cover gasket? I have a friend I normally do mechanical stuff with but I was just wanting to see if I could do it.
I searched the forums but couldn't find anything. Thanks!
2021 m240i on order
02-17-2016, 07:17 PM | #2 |
Rep 870
Drives: 2006 BMW Z4M Roadster
02-27-2016, 04:07 PM | #3 |
Rep 1,805
And this will show you how to remove the valve cover from the S54.
http://www.m3forum.net/m3forum/showthread.php?t=450097
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
03-03-2016, 01:42 PM | #4 |
Rep 588
Dude Yes! Thank you Slick. Should I go ahead and change out the spark plugs too since I'm there? I'm at 87k. Not sure when they were done last.
2021 m240i on order
03-03-2016, 01:56 PM | #5 |
Rep 11,667
You can do plugs anytime without removing the valve cover.
They are accessible under the trim cover. But, if they have never been done; absolutely change them. At the very least pop one out and have a look. At that mileage I'm surprised that coil packs haven't also started to go.
03-03-2016, 02:07 PM | #6 |
639
Rep 3,124
Have you checked the valve clearances?
Valve cover gasket is part of the job, and I always replace the plugs since I have to remove them anyway.
03-05-2016, 10:26 AM | #7 |
Rep 588
Thanks Ian. I'll check em out.
Stick. At 90k I was going to go to a shop and have a valve adjustment done. I was just going to do the valve cover gasket myself just to have something to do.
2021 m240i on order
03-05-2016, 10:43 AM | #8 |
Rep 11,667
I agree with StickMon, hold off on the gasket until the valves are adjusted, it will be replaced at that time.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 03-05-2016 at 10:49 AM.. |
