      05-05-2015, 02:31 PM   #1
eyezayuss3
Drives: 03 Z4
PLEASE HELP convertible top went up but won't go down
So my soft top was torn and I had to replace it. After doing so the top was down after I fully switched it over I tested it to see if it works and it went up no problem, but when I tried to put it down, nothing. I checked fuses and nothing and there really is nothing else I can think of. When I press the button, the light comes on orange or red but nothing. The light to put the top up will not come on at all and I assume it is due to the fact that the to is up. If anyone can help me please do so! Thank you
      05-05-2015, 03:10 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Check the deck in the trunk.
The yellow light usually indicates that the micro switch isn't tripped.
Maybe the deck is up or the tab at the front of it isn't hitting the switch.
      05-05-2015, 03:14 PM   #3
MYovichZ4
MYovichZ4's Avatar
Drives: 2007 Z4 3.0i Roadster
As StickMon says, the Microswitch.
The dials/knobs in the top corners of the picture my trunk
2007 BMW Z4 3.0i Roadster / Silver Grey
BMW CCA 492691
Last edited by MYovichZ4; 05-05-2015 at 04:14 PM.. Reason: added link of trunk photo
      05-10-2015, 03:49 AM   #4
eyezayuss3
Drives: 03 Z4
Awesome thanks to both of you guys! I'm not surprised but you guys were right! Thanks a lot
      05-19-2015, 04:54 PM   #5
trevor
Drives: 2005 BMW Z4 and 2001 BMW 515i
I knew the dealership was robbing when they said they had to reprogram something to fix it...
Tags
convertible
