06-22-2014, 07:33 AM | #2 |
#dubspec
6865
Rep 5,277
Usa= inner halo
Canada = hid and outer egg yolk
06-22-2014, 08:29 AM | #3 |
Rep 4,080
personally I prefer the USA version because it allows you to run with the fogs and all other lights on - except the headlights.
That way you don't get the headlights reflecting back at you in the fog, yet the fog lights are on and your car is lit up all around so it can be seen by others.
Huz-Z
06-22-2014, 08:46 AM | #4 |
Rep 2,651
Drives: Z4MC, X3-35i,525i, Corrado G60
What dubsesd said, unfortunately the halos are too dim to make any difference as DRLs since they don't stand out during the daylight. I think I can add dual halos without needing to cut the headlights open. I'll put up a post if I can get this done.
06-22-2014, 01:32 PM | #5 |
Rep 56
FYI, I have a pair of these on order from E92-Lighting: https://www.e92-lighting.com/bmw-acc...arking-lights/. No guarantees they will be error-free for the Z4 DRLs, but they're the only ones I could find that seem they might work and that had enough emitters to make me think they may be as bright or brighter than the dinky 10w halogen bulbs.
Should know this week how they work out.
06-22-2014, 03:05 PM | #6 |
Rep 429
Just checked mine... It's a Cdn car and I just have inner light (halo?) as DLR. However I've switched mine off-on numerous times with NavCoder when checking car for faults or just plain playing with INPA.
Sent from my smart phone...
06-22-2014, 04:13 PM | #7 |
Rep 4,080
The fogs on my SI are bright enough to function as DRLs. I still think that BMW should have found a way to have fogs on the Z4M.
Huz-Z
06-22-2014, 04:15 PM | #8 | |
Rep 4,080
Are any modification needed to get these working?
Huz-Z
06-22-2014, 06:21 PM | #10 |
Rep 2,651
Those should be brighter than the stock Halogen, but I still don't think they'll be bright enough to use as true DRLs. Those look like they are using 5630 LEDs. I tried some that had 10 5630 LED and they were a little brighter than the stock Halogen, but not by much. The ones you linked looks like they have 22 LEDs, but the 6 on the front won't do much since there's a black solid disk in front of them. Plus they probably aren't driving them very hard since there's not any aluminum heat sink material. Also there's a blue translucent disk between the AE ring and the bulb/reflector. Most of the light has to use the reflector to make it to the AE ring. I know because I dissected a damaged headlight from a wrecked car. I'll post some pics of all the parts that make up the AE light assembly. I think the only way to get a true usable DRL AE is to use a LED ring, which I plan to experiment with.
Here's my LED (on left in picture) vs stock halogen. |
07-10-2014, 09:37 PM | #11 |
Rep 56
Just to followup, turns out that E92-lighting had no availability on the bulbs and eventually had to get my money refunded. After lots more searching domestically in vain, I ended up ordering these from China off ebay: http://www.ebay.com/itm/1-X-BA9S-LED.../200972175548? Claimed output is 500-600 lumens, have no idea if that is accurate but they are indeed bright.
My writeup which includes some comparison photos is here: http://www.zeleznik-klein.com/z4/fixit/drl/index.html. I'm pretty happy with the result, factory halogen on left, LED on the right.
07-10-2014, 10:35 PM | #12 |
Rep 2,651
Looks good. BTW, I doubt those are even 100 lumens.
I think the brightest BA9s LED might be these: Or the more involved and $ LED rings I'm experimenting with as a service: Last edited by pungo; 07-10-2014 at 10:40 PM.. |
07-11-2014, 08:03 AM | #13 |
Rep 56
Thanks for that link pungo, very interesting. If they weren't so expensive I'd buy a pair just to try them out. I will definitely browse his store and see what else he has that looks interesting. My fear of ordering from China has been eased now
FYI, that I also bought and tried these 9x5050 bulbs: http://www.ebay.com/itm/190719769189. They were not error free on the Z4 and they were definitely dimmer than the ones that I ended up installing. Whereas these were barely visible in daylight, the ones claiming 500lm that I installed were clearly visible in noon sun and a little brighter to my eyes than stock halogen. Edit: I see now that the guy is selling 2 bulbs for $32, I initially thought it was the price for 1. Makes it a little more palatable to give it a try, need to look some more before deciding.
07-11-2014, 09:49 AM | #14 |
Rep 2,002
Are the 5-600 lumen LED's you demonstrated above error free? That is my biggest issue. I would go for LED's if they did not throw an error code on the dash.
07-11-2014, 09:55 AM | #15 |
Rep 56
No, not error-free. I have been unable to find anything suitable that is truly error-free. Even the ones from overseas that claim to be error-free I have found that they aren't. The only LEDs that I have bought for the Z4 that are truly error-free is the interior lighting package from ECSTuning and the license plate lighting from LeatherZ. IMO if it is not from a reputable stateside vendor that specifically tests on the Z4, I wouldn't trust whatever they claim.
07-11-2014, 03:53 PM | #16 | ||
Rep 2,651
It's very easy with NCS Expert to tell the light control module to not check the AE so you don't get the error. KALTUEBERWACHUNG_FL - COLD MONITORING OF HIGH BEAMS nicht_aktiv - not enabled WARMUEBERWACHUNG_FL - HOT MONITORING OF HIGH BEAMS nicht_aktiv - not enabled Quote:
07-12-2014, 08:19 AM | #17 | |
Rep 56
07-12-2014, 03:43 PM | #19 | |
Rep 2,651
Look forward to your evaluation of them compared to the other LED bulbs. |
07-12-2014, 04:08 PM | #20 |
Rep 56
Yeah, I've seen the Cree + Samsung bulbs, which are pointless because they put the Samsung chips on the sides which is right where we need the most output for the DRLs! I read some of Cree's technical material and a few other industry articles on the XBD chips. The significant increase in output efficiency and heat tolerance is what convinced me to give the "all-Cree" bulbs a try.
07-15-2014, 12:36 AM | #21 |
639
Rep 3,124
I put these in my panic brake lights.
CREEs all around. Good quality and super bright. They have a BA9s variant.
07-15-2014, 08:00 AM | #22 |
Rep 56
Yeah, those seem to be identical to the ones I bought from a different vendor. Good to know that you had good results, would be interested to see before / after photos if you have them. Interesting that the panic brake lights take the 120 degree offset bay9s bulbs, I didn't think any BMW bulbs had offset pins.
