| 07-28-2019, 02:29 AM | #45 |
![]() 1052
Rep 1,354
Nice! The first kit is soon done. Unless the print fails somehow I will send it tomorrow.
This is the only account I have on Bimmerpost, I will never post my e-mail publicly. If you want to contact me send a PM or you can find me on Instagram: @andre_westersund or @westersund_motorsport
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
| 07-29-2019, 07:04 PM | #46 |
Rep 234
Interested. Sent PM.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
| 07-30-2019, 02:50 AM | #47 |
![]() 1052
Rep 1,354
So several prints have failed, probably due to the size of the ducts and the fluctuation of heat causing the prints to lift in the same corner. The new printer coming in uses another type of base plate which is better and the print won't lift and get ruined. We've never had this problem with the smaller ducts, trail and error I guess.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 Last edited by Westersund; 07-30-2019 at 03:23 AM.. |
eggman51210.50 |
| 08-01-2019, 07:34 PM | #48 | |
765
Rep 7,864
I expected the few odd issues. No problem, keep us updated. The efforts are appreciated!
![]() Quote:
| 08-02-2019, 10:11 AM | #49 |
![]() 1052
Rep 1,354
The new printer arrived today and is already printing, I will keep you updated during the weekend.
wdb5539.50 |
| 08-04-2019, 12:02 PM | #50 |
![]() 1052
Rep 1,354
So we've had some issues with the new printer, the heat bed/base plate isn't 100% straight. But we've spent many hours fine tuning it to get the desired result, it's looking promising now.
| 08-05-2019, 02:24 AM | #52 |
![]() 1052
Rep 1,354
Thank you! A little bit more trouble with this one than expected. As I said before, never had any issues with any of the other kits before. It's most likely the size of this that makes it troublesome.
| 08-05-2019, 11:49 AM | #53 |
![]() 1052
Rep 1,354
Checked on the print an hour ago and it's looking promising, half a cooling duct have been printed without any lifting from the base plate. Seems like the fine tuning is paying off, but we're not out of the woods yet! Hope I didn't jinx it.
| 08-08-2019, 12:19 PM | #54 |
![]() 1052
Rep 1,354
So the print turned out eh... not 100%. It's possible to use it but it needs some work to get the finish were I want it. However it's important to know that a 3D printed part will never be perfect, it's not cast or thermoformed. But this print didn't live up to my requirements. Considering the size of the duct one option is to apply a layer of epoxy resin on the backside of the duct to reinforce it more, shouldn't be needed but it can applied free of charge. If anyone wants it.
And about that base plate/heat bed that isn't straight, we've ordered a new CNC milled base plate from Germany that is thicker and guaranteed 100% straight. That will help a ton as well. I'll keep you posted.
Residentj3553123.50 wdb5539.50 |
| 08-08-2019, 12:50 PM | #55 | |
Rep 218
Drives: 2008 BMW Z4M Roadster
Keep it going! ![]()
2008 E85 ///MZ4 Roadster - Sapphire Metallic Black / Imola Red Int.
IG: Jessed.alvarado Mods: ProFlex E85 Flexfuel kit, Eventuri Carbon Intake w/ RPI scoop, Megan Headers, Custom Axle-back exhaust, KW V3 Coilovers, Stoptech ST40 BBK, Poly FCABs, APEX PS-7s, Diode Dynamics Headlights, CF Trunk Spoiler, Sideskirts & Diffuser. |
Westersund1051.50 |
| 08-08-2019, 02:38 PM | #56 |
20203
Rep 6,451
Wouldnt having it thermoformed be an option (external company).
I mean can you thermoform on a 3d printed mold? (heatwise) Thermoforming is a very inexpensive process, also in low numbers if a 3d printed mold works (manual termoforming machine), there are lots of companies around that do that. You already have the computer model measurements, for thermoforming it just needs little alterations: make a negative copy with maybe some alterations required by the process.
| 08-08-2019, 03:45 PM | #57 |
Rep 348
There is a community member on here - great guy and local to me - named ZeD4Mr who has a line on carbon fiber manufacturing. I dunno if it's in any way feasible to see if they can be done in carbon fiber.
That said, I'm happy to wait, and happy to recognize that you are doing R&D for a small niche market and shit happens... if it takes more time or if you identify reasonable additional costs are required to meet your original quality standards, I think we can all be adults about that ![]() eg |
Residentj3553123.50 |
| 08-08-2019, 04:11 PM | #58 | |
Rep 218
We're all just appreciative of you guys giving us these options! ![]()
Westersund1051.50 |
| 08-09-2019, 01:35 AM | #59 | |
![]() 1052
Rep 1,354
| 08-09-2019, 01:39 AM | #60 | |
![]() 1052
Rep 1,354
| 08-09-2019, 10:36 AM | #61 | |
20203
Rep 6,451
Maybe it also depends on what kind of plastic you want to have thermoformed and how thick the sheets are. I'm sure a thermoforming company can tell you that. I'm sure they've researched the possibility to make moulds for thermoforming by means of 3d printing. But I think thermoforming usually is a very cheap production process, also in smaller batches (less than 50pcs). Its just not engineering wise very precise, but I think this part doesnt need to be I reckon. If you have problems with the production volume wise or timespan wise and cost is a real issue it's I think the first alternative to at least look into. I only dont know if your cones have protrusions at the back, for maybe clips to clip into or screws to screw into. Thats of course not possible with thermoforming (assuming we talk about the same process here; thermoforming by means of heating a sheet and vacuumsucking it over a mould), and desired sheet thickness might also be a limitation. Carbon fiber would be awesome aestetically. But carbon manufacturing obviously is also very very time consuming and therefore very expenisve. But making it out of carbon would sure be an eye catcher
| 08-09-2019, 12:55 PM | #62 | |
![]() 1052
Rep 1,354
I've just messed around a little with glasfiber and I don't think it would be able to make it good looking enough in carbonfiber. We do offer the ducts in CFRP.
| 08-09-2019, 01:02 PM | #63 |
![]() 1052
Rep 1,354
As promised, some pictures. The quality isn't 100% on this one, it can be a little better with some fine tuning. We've built an enclosure for the printer now to slow down the cool down process and to keep heat around the part for longer. When the part is done it will cool down slowly instead of cooling down faster bit by bit as the printing progresses. We're hoping this will yield a better end result.
rockstar93327.00 Residentj3553123.50 |
| 08-09-2019, 01:27 PM | #64 |
Rep 528
Drives: E86 Z4MC; E92 M3
Well I'm sold. Those look great and I love how many people are stepping up to develop for this platform.
Regarding the CFRP, any benefits other than aesthetic? Stiffer, lighter, etc?
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
| 08-09-2019, 03:10 PM | #65 |
Rep 218
Is there a picture of the CFRP material and how it would look when finished?
| 08-09-2019, 09:02 PM | #66 |
Rep 348
Looks awesome! Appreciate the progress reports. Wondered if these could be made into a mold, then use other material to manufature them?
If you are planning to reinforce these, I would definitely go for that, let me know if there is any additional costs. |
| Bookmarks |
