07-25-2011, 09:45 PM | #23 |
Rep 4,531
07-26-2011, 08:38 AM | #25 |
Bad Lieutenant
237
Rep 3,517
If they brought him in, must have been for a good reason. Took me 5.5 hours with a couple of grub sessions. Did he give you the spec sheet so you know which valves needed adjustment for future techs?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Coby Alcantara | StrongStrut STB
07-26-2011, 09:24 AM | #26 |
Hug the road... Carpe Asphalt
106
Rep 722
At what mileages are the valve checks due? I can't get access to the maintenance schedule posted here.
Anyone has done this at the dealer or indy shops, how much $$?
2007 BMW ///M Coupe
07-26-2011, 10:15 AM | #27 |
Bad Lieutenant
237
Rep 3,517
I believe it's around 600-660 gallons of fuel ~25k miles. Out of warranty, dealers charge from $1100-1400, indie shops seem around $600-800 around here.
07-26-2011, 10:24 AM | #28 |
106
Rep 722
600-660 gallons @ 22 MPG is ~13k-14k miles ?
I doubt we get 39MPG if 25k miles and 600-660 gallos is the correct figure... Will the car computer indicate the valve check is due?
2007 BMW ///M Coupe
07-26-2011, 10:38 AM | #29 |
Bad Lieutenant
237
Rep 3,517
Sorry man, 660 gals is the oil interval. the valve adjustment seems to hit around 25k, some going through fuel faster have had to have it done earlier. I like to do it every 15k, regardless as it's not that difficult, just time consuming.
07-26-2011, 11:06 AM | #30 | |
Rep 4,531
He might of exaggerated a bit on the time, who knows. I wasn't very happy that they couldn't do the car that saturday (when they were open). He was complaining how long it takes... I then replied, at least you can access cylinder #6 unlike the E46 Ms. |
07-26-2011, 11:40 AM | #31 |
Rep 331
07-26-2011, 11:49 AM | #32 |
M = Midlife Crisis
67
Rep 2,006
Takes a solid 3 hours just for the valve work and associated assembly/disassembly. The fluids are an hour in addition.
2006 Z4MC - #LL93158
07-26-2011, 12:49 PM | #33 |
Bad Lieutenant
237
Rep 3,517
My "back" told me it was about 5 hours
07-26-2011, 01:14 PM | #34 |
Rep 11,667
Yeah, it's definitely a good half day job; depending on the # of shims to be replaced.
It's a VERY satisfying DIY, knowing it's done right.
07-26-2011, 01:28 PM | #35 |
Bad Lieutenant
237
Rep 3,517
Yes, agree. Lots more room, especially in the rear, than the E46 bay, where you'd want a mirror to see if the rear gasket was setup properly. Zed engine bay is a thing of beauty when it comes to roominess.
07-26-2011, 01:53 PM | #36 |
Rep 245
Drives: fairly quickly.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue |
07-26-2011, 02:07 PM | #37 |
Rep 66
Anyone have any experience with this specific issue in NE PA. Also, my M is an 08 and under Insp I in the maintenance manual that came with the car, "check and adjust valves" is NOT listed under inspection I. Since BMW took it off the list of items inspected on the documents that came with the car, I'm expecting a big hassle. But I'm going to feel my dealer out anyway.
07-26-2011, 02:47 PM | #38 |
Rep 134
Caddy, you are in ontario. how many times have you made it on your car ? mine is a 2007 with 35000 km. warranty (US car) is ending in january 2012. Car will be sleeping from october so, its before october under warranty (if accepted) or from somebody else in 2012 .
engine seems to run great. my only problem is, the check engine is ON for the 2nd time in 2 month. visited the dealer that say it was a O2 sensor. they tested all and ,supposed they were all ok. BUT, problem is back... any relation to the valve job ? |
07-26-2011, 03:03 PM | #39 |
Rep 11,667
07-26-2011, 04:55 PM | #40 |
M = Midlife Crisis
67
Rep 2,006
07-26-2011, 08:57 PM | #41 | ||
Rep 238
07-27-2011, 11:42 AM | #42 |
Rep 283
I dropped my car off this morning and they told me it would take an hour to do the inspection. I again mentioned that it was an M, not a standard z4 (coincidentally there was actually a 3.0 coupe in the service bay) and had the s54 engine and that they couldn't possibly do it in an hour. At that point one of them went to talk to a manager and said they would provide a copy of the valve adjustment report, so I guess they still do this. In the mean time I have a Chrysler Sebring. Wish me luck.
07-27-2011, 12:00 PM | #43 | |
Bad Lieutenant
237
Rep 3,517
07-27-2011, 12:29 PM | #44 | |
106
Rep 722
Once you get a copy, can you share the valve adjustment report with us?
How many miles are on your ODO? Thanks and good luck! Quote:
2007 BMW ///M Coupe
