Thread Tools |
| 06-12-2025, 09:14 PM | #23 |
Rep 353
Drives: BMW Z4C 3.0si 3 pedal
Neither are offset. Just a difference in hardness of the polly. I've run both. Zerk fittings are one of the reasons for the choice as well.
Food for thought, with the ZHP lower control arms and if running any sort of camber plates I'm not certain the offset bushings will add much that you don't already get from the camber plates. Running fixed camber plates and notched the towers and additional 5mm you can get up to -3° of camber depending on if pushed all the way in or out on the towers. |
| 06-13-2025, 06:04 AM | #24 | |
![]() ![]() ![]() 2980
Rep 12,994
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
| 06-13-2025, 09:34 AM | #25 |
![]() 12
Rep 106
Correct. Camber and caster are two separate things. Caster is the steering axis "tilt" when viewed from the side.
| 03-02-2026, 07:32 PM | #26 |
Rep 24
I’ve always run oem or hd oem ie meyle - disappointed last year with a fresh set the front was bouncing with hot brakes like it had warped rotors (they were also new) - get a dud now and then, missed two session darn it.
| Bookmarks |
