Thread Tools |
| 03-25-2011, 10:42 AM | #1 |
M addicted
137
Rep 342
CDV delete - is this right part?
| 03-25-2011, 12:09 PM | #2 |
Bimmer Noob
33
Rep 568
![]() 08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
| 03-25-2011, 12:16 PM | #3 | |
M addicted
137
Rep 342
| 03-25-2011, 02:45 PM | #6 |
![]() ![]() ![]() ![]() 31
Rep 615
+1 on this. For those that are already out of warranty or soon will be, it is a complete waste of $30-$35. The brake line screws into the clutch slave cylinder without the CDV with no issues at all. A perfect example of "less is more".
| 03-25-2011, 03:01 PM | #7 | |
M addicted
137
Rep 342
| 03-25-2011, 03:52 PM | #8 |
Rep 1,776
Drives: 2007 Z4M Coupe
is there DIY on this? I like to remove mine completely
![]() Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
| 03-25-2011, 04:49 PM | #9 |
Rep 416
| 03-25-2011, 08:12 PM | #11 | |
Rep 11,671
nada
| 03-26-2011, 12:22 AM | #12 | |
![]() ![]() ![]() 49
Rep 510
The only difference will be on the shield you remove to access the transmission. Only need to remove one shield where this write up talks about removing two. Will be pretty obvious once under the car. I'm sure you can find other references by searching, but this is the guide I used. One other thing. Not sure if this write up talks about it, but use a c clamp on clutch line to squeeze the line closed just before the valve. It's a good idea or otherwise you'll drain the entire reservoir.
![]() |OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| Last edited by jdl1pt; 03-26-2011 at 11:35 PM.. |
| Bookmarks |
