10-17-2010, 04:05 PM | #1 |
Rep 12,570
Lowest Offset on 9.5" Rear on Non-M Coupe?
Just like the title says, what's the lowest offset I can get away with on a 9.5" rim on the rear of my non-m Coupe? Stock sports suspension and don't want to roll the fenders.
I think I've seen non-M roadster owners report saying they were able to get the stock M wheels to fit, but wasn't sure if they still encountered rubbing on bumps. I believe stock M offset rear is 27? And assuming I'm keeping to stock height, wheel diameter (18" vs 19") should not matter as long as I choose the correct profile tire? |
10-18-2010, 12:52 PM | #2 |
Rep 409
i'm sure others would agree...
for rear offsets on a non-M... with stock sport suspension w/out adding negative camber w/out letting the tire stick out past the fender w/out body modification 9.5" width = et42 9.0" width = et35 8.5" width = et29 basically, any offset that pushes the outer edge of the wheel a maximum of 21mm past stock (8.5 x et50).
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
Last edited by v3.0si; 10-18-2010 at 01:29 PM.. Reason: clarification on dimension. |
10-18-2010, 05:55 PM | #3 |
Rep 12,570
thanks, very helpful...
10-18-2010, 06:16 PM | #4 |
John 14:6
59
Rep 588
I believe the lowest offset you can run on a 9.5" wheel is a 32 offset. I was able to run a 19X10 wheel with a 35 offset with 265/35/19 tire without any rubbing on a eibach/koni set up. Stock M wheels do have a low offset, however they're not that wide of a rim.
Are you planning on another set of wheels?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
10-18-2010, 06:39 PM | #5 | |
Rep 409
10-19-2010, 10:12 AM | #6 | |
John 14:6
59
Rep 588
10-19-2010, 10:37 AM | #7 | |
Rep 12,570
10-19-2010, 12:20 PM | #8 |
John 14:6
59
Rep 588
LOL, in the back of mind, me too...once I get rid of my 2nd set.
10-19-2010, 12:46 PM | #9 | |
Rep 12,570
10-19-2010, 01:31 PM | #10 | |
Rep 409
i'm measuring flush at front to be... 9.0" width = et42 (may have suspension clearance issues 8.5" width = et35 8.0" width = et29 also... i've read on this forum, several posters are having clearance issues with the 8.5" x et35 using 235 tread width. since all of the above measurements use a gain of 18mm over stock, all of these may have the same rubbing issues. my personal plan is a set of front at 8.0" x et35 and a rear of 9.0" x et35. this way i'll be able to go the stock ///M tires.
10-19-2010, 01:47 PM | #11 | |
Rep 12,570
