      01-24-2010, 10:57 AM   #23
stubble88
Drives: 2013 e92 ZCP blue
wheel weight
front: 24.69 lbs
rear: 25.79 lbs
heavy!!
      03-13-2010, 11:02 PM   #24
phenolic
Drives: Z4M
More than simply looks and fitting without rubbing, would anyone like to comment on handling characteristics of certain sizes and offsets?
Anyone with experience with handling of Morr VS7 or VS8?
      03-25-2010, 09:33 AM   #25
dekaliber
I'm curious whether Z4 3.0si wheels will fit on an M (style 135 or 203). I have a set of 135s that I currently use for my Z4 in the winter, and would prefer to keep them if I can when/if I get an M Coupe.
The front/rear sizes are:
8x18 ET 47
8.5x18 ET 50
All wheels are fitted with 225/40R-18 winter tires (same size as Z4 fronts).
Based on the calculator at http://www.rimsntires.com/rt_specs.jsp, the diameter would be almost 1" shorter and the wheel would be 0.2" closer to the suspension/brakes both front and back. Is this perceptible/safe?
      05-20-2010, 02:55 PM   #26
shaunbmw
Drives: 2006 z4 m roadster
19" wheel size - fit?
I'm looking at moving from an 18" to a 19" size. Will the following setup running Generals fit?
19x8.5 +32
19x9.5 +28
Thanks.
      05-20-2010, 03:53 PM   #27
shaunbmw
19" fitment
Hi,
I called Tuner motorsport and they advised the 19x8.5 +32 (235x35x19) / 19x9.5 +28 (265x30x19) setup won't fit on the front. Any idea whether
19x8.5 +35 (235x35x19), 19x9.5 +30 offset (275x30x19) will fit?
      06-15-2010, 07:38 AM   #28
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
i've got a couple of questions. what does ET stand for and what does it mean?
and, will 305's fit on the back? i don't think i want to spend 305 money, but just curious. had a convo with a coworker. i don't think they will. thanks!
      06-15-2010, 08:32 AM   #29
Drives: M2 Comp
ET is the wheel offset.
How much the center line of the barrel measures from the face of the hub.
I don't know how true it is, but I read somewhere that ET is from the German word 'Einpresstiefe' translated as 'insertion depth'.
      06-15-2010, 08:51 AM   #30
007MCoupe
007MCoupe's Avatar
awesome, thanks for a picture. i've been googling like nobody's business and wasn't getting anywhere.
      06-15-2010, 09:00 AM   #31
Drives: M2 Comp
BTW when your lady asks you about your 'Einpresstiefe',
be careful how you answer.
      06-15-2010, 10:20 AM   #32
007MCoupe
007MCoupe's Avatar
heh heh thanks for the heads up
where's a good site to browse/purchase rims? i don't have anything locally, but there's dallas 4 1/2 hours and san antonio 3 1/2 hours away. can't get on ebay at work...
      06-15-2010, 11:02 AM   #33
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
You might look at joining the DFW Auto Club (www.dfwautoclub.com) which is a very tight-knit group of enthusiasts in and around Dallas Fort Worth. Not the typical car group and there are a few hand selected very involved sponsors, one of which is Peter at Wheel Experts who would be a good person to call.
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      06-15-2010, 11:56 AM   #34
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
+1 Jragan mentioned it to me and it was great advice. Cool group of guys! I still need to meet you Jragan and convince you to get another Z4M
      06-15-2010, 03:12 PM   #35
007MCoupe
007MCoupe's Avatar
awesome thanks! like i said i'm 4 1/2 hours away from dfw area, but i'll see what i can get into and get some info about it.
      06-17-2010, 09:15 AM   #36
007MCoupe
007MCoupe's Avatar
also...do we (I) want a lower or higher offset?
      06-17-2010, 11:00 AM   #37
dekaliber
A lower offset will cause the wheels to stick out more and be more flush with the fender. Most people try to achieve less vertical space between wheel well and tires, and less horizontal space between fender and wheel. If you pay attention at expensive cars that look "nice," they've usually paid a great deal of attention to optimizing both these points. However, you can only go so far until your tires start rubbing on either the wheel wheel lining or fender.
It's all good up to a point, but personally I can't stand the ridiculous "hella flush" look that some people go for where they combine low offset wheels/spacers, drops, and simply stupid amounts of camber to create a car that looks like it came out of a cartoon.
      06-17-2010, 11:41 AM   #38
Blind32
Blind32's Avatar
Drives: '07 Z4MC
These sites help give a visual.
http://www.1010tires.com/wheeloffsetcalculator.asp
http://www.kgm.tiwing.com/calcs/offsetcalc.htm
There is also an iPhone app. named Rim Offset $1.99......they got me, I'm an easy sell!
      06-18-2010, 09:46 AM   #39
007MCoupe
007MCoupe's Avatar
I just got the new EVO 4G from sprint so i'll see if they have something. haha
thanks for the breakdown! that really helped. just wnat to make sure i make the right decision when it comes to it
      07-12-2010, 04:19 PM   #40
ZStig
instagram 997turbotom
296
Drives: Alpina XB7
19 x 10.5 et 27 on the rears?
      07-12-2010, 05:29 PM   #41
crfine88
crfine88's Avatar
447
Drives: E86M
Unless you strech a 265 or 275/30/19 (this is bad for performance) they will rub. Some run run 275/37/19's, but these will rub where the rear bumper and fender meet. 285/30/19 is the right size for the wheel width and has the same diameter as stock.
To fit the 19X10.5 et 27, you will have to make some fender modification and remove part of the plastic fender liner.
suprtran115.00
      07-12-2010, 09:04 PM   #42
onebluemcm
onebluemcm's Avatar
74
Drives: '07 Z4MC
I'm assuming these will fit - I've been told so and the person that told me is certain about it himself.
18x9 +38
18x10 +27
255/40 front an 285/35 rear
My concerns? Up front, clearance with the strut. In the rear, should be fine but might be pushing it on the outside with the fender.
Custom designed, engineered and build wheels for E46 M3 however, as I said, I've been told that they'll fit the Z4MC - this from the guy that designed and engineered them and supposedly owns a Z4M too.
Opinions anyone?
Partly don't know why I'm asking, they'll be here next week, should have tires pretty soon so I'll let you all know for sure. Admitedly, it's been a bit of a leap of faith...
      07-12-2010, 10:23 PM   #43
ZStig
296
Drives: Alpina XB7
hmmm. I def wanna go with something that'll fit 285s in the back. I guess I'll stick to 19 x 10s
      07-14-2010, 04:24 PM   #44
crfine88
crfine88's Avatar
447
Drives: E86M
18x9 +38
18x10 +27
Opinions anyone?
These will fit.
Rears may rub the plastic fender lining a little under heavy compression if the car is lowered more than an inch. Front may rub a little on the inside depending on your camber and ride height. With stock suspension, you should hav no issues.
