      04-08-2010, 04:01 PM   #1
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Question Heavy 19"s to OEM 18"s...your thoughts.
My 03 Z originally came with 16"s. I'm sure many of you already know when you upgrade to aftermarket 19"s, there's a noticeable difference in ride quality (harsher ride) and MPG. This may not be the case when you buy top dollar light weight wheels of course.
So I'm on my third set of 19"s and I'm tired of the harsh ride and the lower MPG. I'm planning to mount a set of powdercoated OEM BMW style 197s made by BBS on a set of 225/40/18 in the front and 255/35/18 in the rear tires (factory fitment). These should be considerably lighter than my staggered 19" Miro wheels on 235/35/19 front and 265/30/19 rear tires.
Should I expect to notice an improvement in the ride quality and improvement in MPG? I'm hopeful, but would like to hear your thoughts. Thanks .
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      04-08-2010, 09:03 PM   #2
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
How heavy are the 197s and how heavy are the miros? Ive got a 2.5 and I am thinking about the 18 csl reps. I am hoping the increased rubber will offset the increase in weight.
      04-09-2010, 12:48 AM   #3
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
According to my research (online), the miros are 34 lbs in the front and 36 lbs in the rear, compared to the 197s which are 24 lbs in the front and 26 lbs in the rear. So basically, a total savings of 40 lbs to the wheels, 10 lbs each f/r side.
      04-09-2010, 01:24 AM   #4
GothM
Oversteer Enthusiast
GothM's Avatar
Drives: '06 M Coupe, Black Sapphire
36 lbs!? Holy.....
      04-09-2010, 01:45 AM   #5
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
I recently swapped from 19" vmr csl's 30lbs to 19" morr vs7's 19.5lbs. The difference was night and day and I vow to never put heavy rims on any of my cars again. Where my shocks felt severely underdampened w/ the vmr the vs7 feels so much lighter on it's feet, and no more crashing over bumps. Acceleration feels like a lightened flywheel effect...harder to drift the car now but more control/agility in corners. You are doing the right thing! My mileage sucks either way so I can't comment
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      04-09-2010, 02:56 AM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Your acceleration should improve dramatically. I read somewhere that the rule of thumb is removing 1 lb of unsprung weight is the performance equivalent to removing 10 lbs of sprung weight. Obviously this depends on the car, as a torque monster that red lines at 6k rpm with a powerglide (2 speed) won't suffer as much from an increase of rotational mass as a 6 speed 8k rpm Bimmer. I'd also assume the rule applies primarily for the rear (drive) wheels. Or, I could be talking out of my ass. But as a reasonable person I can tell you that your acceleration will improve significantly.
      04-09-2010, 08:55 AM   #7
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
those are some heavy ass wheels, you should definitely notice increased acceleration. 24lbs is about the weight of the CSLs, let me know how they feel as you wheel weight and tire size is the same as what I am considering.
You dont happen to know the weight of the stock 16s do you?
      04-09-2010, 10:29 AM   #8
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Sorry, I can't recall the weight on the 16s. I do recall the improvement in MPG...2-3 extra MPG.
