07-30-2009, 07:52 PM | #23 | |
Rep 24,685
Drives: '04 330i ZHP
I mean if I go for the 70-200 2.8 then I could always just upgrade my 50mm to the 1.4 but like everyone says its not that big of an upgrade. So what does everyone think? 70-200mm 2.8 L (non IS) and the 50mm 1.4 = about $1600 total (leaves me $400 for a new bag and nice tripod. or 70-200mm f4 L (non IS) and 50mm 1.2L = about $2000 total unless I can find some good lightly used deals |
07-31-2009, 12:28 AM | #24 | |
Rep 9,788
On a serious note, I don't know if you really need the 50mm 1.2L. I mean I don't know of too many people with it and IMO you probably won't need anything more than 1.8/1.4. I don't know though- you have to try everything out and pick the lenses that are right for your style. As for the 70-200mm, the F/4.0 is the sharpest of the bunch but the difference is only noticeable if you pixel peep. So if you need/want to use the 70-200mm 2.8 for concerts, I would recommend going with the IS version. Unless you will always have a monopod/tripod on you, IS is helpful in such situations (unless you're able to use a fast enough shutter speed). Of course it's more expensive but you should always have it and don't need it than the other way around. Besides, you could always sell it and buy a 2.8 non-IS later. |
07-31-2009, 01:40 AM | #25 | |
Rep 24,685
See the thing with the IS is that in concerts, you don't want a lot of motion, you want to stop it so shooting at 1/40, even 1/30 with IS is gonna still make them look weird. I try to shoot at 1/125 if possible or minimum 1/60-1/80. I just don't think the IS is necessary so I'd rather have the 2.8 to be able to shoot at 1/60 or above than to shoot at 1/30 with the F4 but have IS on. With the 50mm 1.2L, the 50mm prime is like my favorite lens and I have the very unreliable 1.8 version. I could just get the 1.4 but I figure I'd actually really like to use it often so maybe I should invest in the 1.2L since it'll be sharper and the bokeh on it will be sick. you think its a waste of the $1100 difference from the 1.4? |
07-31-2009, 08:26 AM | #26 | |
Rep 7,389
Having said that, I'd go for the 70-200 f3 L IS with the 50mm 1.4. If the 1.4 is not an L, then I'm worried because it seems like it may end up being your money-lens on stage. If that's true, I take it all back and say you should get the 1.2L before anything else and save to by the 70-200 f4L IS later. BTW, stage lighting is usually plenty for an f4 in a reasonably fast camera. The trouble is you'll have to make big color balance changes in processing. Dave
07-31-2009, 08:55 AM | #27 | |
Rep 7,389
Dig up all the lens reviews and tests that you can find, because even the L-series do vary from model to model. One may be stunningly sharp and the other L only very good. I'm not in the market for this range, so I don't have a clear opinion, other than Ls are worth saving for. You never know, but some of the non-Canon lenses are particularly sharp, like the Ziess wide angle, so don't limit your search to Canon. Limit it to very high quality glass. Dave
07-31-2009, 10:34 AM | #28 | |
Rep 24,685
Also, bigger show stage lighting is usually f4 capable but a lot of times I'm shooting in smaller clubs with not as good of lighting so 2.8 is where I'm at most of the time if not lower |
07-31-2009, 10:34 AM | #29 | |
Rep 24,685
07-31-2009, 12:06 PM | #30 |
Rep 2,355
I'm sorry, you guys'd be kidding yourself if you can hold your 70-200 f2.8 (non-IS) steady even just at 1/60 speed without any sort of support (mono/tri pod or something). that lens together with a body will weigh more than 4-5 lbs, and if you add an external flash, you're looking at 5 lbs of hand held easy. I wont say that I work out a lot, but thats a big piece to hold steady to take shots. You need the IS for either version, unless most of the shooting you're doing will be outdoors.
Having the IS doesnt give you 1 more stop or allow you to really to shoot at 1 stop lower shutter speed IMO. It just ensures that even at 1/60 handheld, 4 out of 5 photos (assuming you have steady hands), will come out decent. For an indoor shot, (i.e. concerts), you need 70-200 f2.8 IS WITH a monopod to really maximize your shoot IMO. (sure, usually stage lightings are enough, but we all know, the color balance usually are whack and you'd really want to shoot at highest speed possible) There are too many variables. Udub, go for your option 2!! hah, 50mm 1.2L is awesome! But, if I may, I'd rather have this combo though. 70-200mm f4 IS, 35mm f1.4L. 50mm f1.4 is actually a very well-built glass and its performance is amazing for its price. I dont own one, but I borrow it from my friends from time to time. I have never tried the 50mm f1.2.. but because I also have a crop body, I find 50mm f1.2 is too far out for me for an everyday use. I'm waiting on the 35mm f1.4 MK2 that is supposedly coming out later this year. I just hope that the 35mm f1.4 will stay under $1500 after they jack up the price.....(or just go for 35mm f1.4 MK1 for $1200?)
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach 2008 E92 335i (sold) |
07-31-2009, 12:12 PM | #31 | |
Rep 2,355
I am just saying, even at f2.8, like you said, in an in-door situation, even at say ISO 1200, you'll probably still need to shoot at 1/60 to get some clear pictures (I'm assuming no external flash used). I'm just saying, IS really helps a lot in low-lit environment, even tho at 1 fewer stop in the aperture. Obviously, cant argue against the 24-70, since that was one of the lens that I was considering before my 17-55, but oh well, until I go FF, 17-55 will do. For zoom lens everyday combo, I personally love my set up of 17-55mm f2.8 and 70-200 f4 IS.. All the rest, only prime glasses do the justice IMO.
07-31-2009, 12:21 PM | #32 | |
Rep 24,685
I think I'm gonna look into a 50mm 1.4 and then a 70-200mm 2.8 IS (probably used though) |
07-31-2009, 12:21 PM | #33 | |
Rep 7,389
Dave
07-31-2009, 12:23 PM | #34 | |
Rep 2,355
Everyday carry, travel carry? If for everyday carry, I use a lot of these inserts and buy some foams from B&H as well. http://www.bhphotovideo.com/c/produc...ed_Insert.html I just use any stylish standard size messenger bag and put in the inserts! They work wonders! I have like 5 or 6 Diesel bags for my camera.. haha OR this one, if you have bigger travel bags. http://www.bhphotovideo.com/c/produc...ra_Insert.html
07-31-2009, 12:23 PM | #35 | |
Rep 24,685
07-31-2009, 12:27 PM | #36 | |
Rep 7,389
Without IS, you'll surely want a good monopod. (Love my CF Manfrotto). You may look a little geeky, but it sure sharpens things up. Dave
07-31-2009, 12:29 PM | #37 | |
Rep 2,355
(hence my previous post about looking at 35mm f1.4, instead of 50mm, which I usually just borrow my friend's 50 f1.4 anyway) Oh, Udub, I just want to add that, the insert I recommend, I can put and I carry these daily for my gear. This insert will fit my 50D with 17-55mm f2.8 lens 70-200mm f4 IS 580EXII a CPL. I highly recommend. Who says camera bags have to be dull-looking..
07-31-2009, 12:33 PM | #38 | |
Rep 2,355
I agree that the IS really makes a difference in low-lit situation, almost enough to offset the 1 extra stop. Also, for me, I could have gotten the f2.8 IS, but it is just the weight of f2.8 and there is no way in hell I'm gonna take that out on my leisure/travel trips.. just way too heavy. (PS. 70-200 f4 is almost exactly half the weight of f2.8 IS!! 1.7lb vs 3.2lb !!!) I am pro-IS myself, but lets face it. some of the best lens usually dont have IS...
07-31-2009, 02:02 PM | #39 | |
Rep 7,389
I was really disappointed that there wasn't an IS version of the 400mm f5.6L available. The cost difference isn't usually large to get IS, when it's available. They're slowly filling in the gaps, but there are still very significant gaps. The 100-400 L has IS and doesn't weigh a bunch more, but I went for the 400mm 5.6 because of its IQ reputation vs. the variability reported in the 100-400. Dave
07-31-2009, 03:18 PM | #40 |
Night Sh1ft
467
Rep 3,079
Drives: F95 X5MC LCI
how about the canon 10-400 F 1.2 IS L?
I hear it comes with a backstrap and a ground stabilizer fold out arm
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
07-31-2009, 03:26 PM | #41 | |
Rep 2,355
What kinda of photography do you usually do? Unless I do some serious track/sporting event photos, I dont think I will ever need a glass like that. If you make one, I'll buy one..
07-31-2009, 04:40 PM | #42 | |
Rep 7,389
I'm really just getting started with the birds and just bought the 400mm. If I've taken between 1000 and 2000 images with it by year end, then I'll start budgeting for a 600 mm Big Bertha style lens. Those are urber expensive. Even a used Sigma is like 3-grand. I can afford it, but I don't want to spend money buying something that expensive and just have it sitting in the closet. Dave
08-01-2009, 12:06 AM | #43 |
Rep 24,685
hmmm maybe I will get the f4 IS then... just gonna suck when I know I coulda had the 2.8 IS and been even 2 stops lower for a better shot.
I just don't think I wanna fork over the coin for it... I'm not even worried about the weight. |
08-01-2009, 04:02 AM | #44 | |
Rep 226
if i were to shoot on a crop body, i would definitely be using the 17-55 2.8IS as my main lens. i'm still waiting for canon to release a 20-70 2.8LII with IS |
