09-02-2008, 08:18 PM | #265 |
Rep 18,880
Drives: BMW
The number determines the hardware batch - without it, I will have to see the module in person to perform a read.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
09-03-2008, 11:46 AM | #266 |
Rep 184
Let me pull it out, Tom, thanks!
Why would it have worked properly before and not now? Is there anything I did so I can avoid it in the future? |
09-03-2008, 11:51 AM | #267 |
Rep 18,880
Drives: BMW
Could be a number of things, but I cannot go any further until I can get all the info required.
09-03-2008, 02:08 PM | #269 | |
Rep 18,880
Drives: BMW
1. Disconnect iPod from cable 2. Remove battery cables, negative first 3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system. 4. Allow cables to remain disconnected for about 5-7 minutes 5. Reconnect battery cables onto battery, negative last. 6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed. Let me know if these steps correct the problem, if not - we'll make arrangments for the module to be replaced under warranty.
09-03-2008, 02:15 PM | #270 |
Rep 184
Wow...that's a lot to go through just to get the unit from setting the repeat song setting. I will try to work on this tonight. Thanks!
09-05-2008, 03:02 PM | #271 |
Rep 184
It just went through this process while waiting for Hurricane Hanna to arrive. In the garage, it appears to have worked. I didn't turn the car off and back on to see if it went back into repeat mode. Thanks for the help!
09-15-2008, 01:46 PM | #274 | |
Smiling Politely
1384
Rep 29,118
does anyone else hear a popping sounds when starting up their car and the last input on the radio was on the DICE.
08 z4m w/nav. also does anyone hear some sort of static/feedback. Its the same kind of sound when you bring phone really close to a cheap am/fm radio and you hear that feedback.
09-15-2008, 03:33 PM | #275 | |
Rep 18,880
Drives: BMW
09-15-2008, 03:40 PM | #276 | |
Smiling Politely
1384
Rep 29,118
connections are tight, no loose/bent pins
09-15-2008, 07:42 PM | #277 |
Rep 18,880
Drives: BMW
Where are you located in CA, are you anywhere near our facility in Santa Ana?
09-16-2008, 11:48 AM | #278 | |
Smiling Politely
1384
Rep 29,118
no, san diego....unless you guys are available weekends.
09-16-2008, 11:52 AM | #279 |
Rep 18,880
Drives: BMW
Only Monday-Friday, but if you can get some time off - I would be happy to take a look at your system for you.
09-16-2008, 11:55 AM | #280 | |
Smiling Politely
1384
Rep 29,118
Hmm....gonna be very hard but we'll see if I can ever make it out
11-11-2008, 12:34 PM | #281 |
Rep 18,880
Drives: BMW
USB Charging support has been announced for the following iPod models:
iPod Classic 80/160/120 GB iPod 4th Generation nano iPod Touch 2nd Generation iPhone 3G Please see this thread for more details: http://www.zpost.com/forums/showthre...44#post3625144
02-25-2009, 06:30 AM | #282 | |
Rep 701
When you turn the ignition off without stopping the Dice/iPod and you turn the ignition back on again you get a couple of loud cracking sounds through the speakers. I can also hear a little bit of static sometimes in quite passages of music and when I turn the system on for a few seconds at the start along with the annoying cracking sound. Tom, have you heard of this?
02-25-2009, 01:03 PM | #283 | |
Rep 18,880
Drives: BMW
02-25-2009, 02:39 PM | #284 | |
Rep 701
It is the Trunk Kit with 15ft of connection cable between the Dice module and the CD stacker wires. Would this make a difference?
02-25-2009, 03:08 PM | #285 | |
Rep 18,880
Drives: BMW
Problem is that we need to see this in action, or have the kit returned for bench testing to see if we can recreate the problem on here. If so, then we can determine the kit is the source of the issue and have it exchanged if still under warranty.
04-10-2009, 11:03 PM | #286 |
Rep 19
Hello there I have had my dice for a few weeks now and I was really enjoying it. However, today the display has switched and I only get one visible character which scrolls through the spelling of the artist or playlist. I have tried to switch the display using disc6 button but I am having no luck. Any helpful advice?
Cheers |
