FS: KW Clubsport 2-wayCoilover Suspension Set (incl. camber plates) for Z4M E85 / E86
USD 3,000.00
Installed and used for less than 500km! Will be removed and ready to ship in April.
$3500 USD shipped to Continental US and Canada. Also available for local pick up in Toronto.
KW Clubsport: 2 Way - These set ups were specifically designed by using the optional adjustable top mounts, suspension geometry can be adjusted to the requirements of the tires and the intended use.
These adjustable top mounts coupled with the independently adjustable rebound and compression dampening technology individual set up adjustments according to vehicle load, tire characteristics and different track conditions. Clubsports meets all needs for the road and the race track guaranteeing excellent handling, best performance, great agility and fantastic lap times.
The exclusive KW patented system has dual level valves that allow for adjustment of the rebound dampening for your road comfort and the compression dampening that controls the driving dynamics.
Feature
Independently adjustable rebound and compression damping technology
Stainless steel technology "inox-line"
Continuous lowering
High-quality components for a long-term durability
Adjustable rebound damping with 16 precise clicks
Adjustable compression damping with 12 precise clicks
Unique independent damping force adjustment
Optional spherical bearing aluminum top mounts
Lowering adjustment ranges
Front from 0.4" to 1.5"
Rear from 0.2" to 1.4"
