Thread Tools |
| 12-21-2025, 06:56 PM | #1 |
Rep 61
MStache2 For Sale
Price - $180. Sold the car last year and I only have 2 items remaining from it. The MStache and OEM interior door soundproofing panels. Had the MStache2 on the car for 1.5 summers before I removed it once I had suspension work done for more committed track use. I drilled 2 holes through it to secure it to the fascia and had double sided tape doing the balance of the work. Had some other screws that were just outside the lip with large washer to secure it as well. Took a cone for a ride as I decided to cut some grass instead of stay on the track one day which resulted in a small crack which I repaired. The repair is shown in the pictures. This does not compromise the structure whatsoever as the crack was only 1" max in length prior to the repair. It is solid and it can be blended perfectly so that it will not be seen. Will ship at purchasers expense (NOTE: This is coming from Ontario Canada). ![]() ![]() ![]() ![]() ![]() Last edited by HBC; 12-21-2025 at 06:58 PM.. Reason: price added |
| Bookmarks |
