![]() SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Thread Tools |
| 04-11-2025, 10:21 PM | #1 |
![]() ![]() 7790
Rep 7,646
KW V3 opinions?
Anyone running KW V3s in 2025 have thoughts on the ride quality vs stock or Bilstein B6? I have heard the rear springs can bind on full compression but not sure if it's a big issue or that uncommon. Torn between these or just going B6 and possibly trimming the internal bump stop a bit.
Thanks! |
| 04-12-2025, 02:07 PM | #2 |
![]() ![]() ![]() 2980
Rep 12,994
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
I actually think spring bind is pretty common for many setups. Most times it can be dialed out adjusting the pre-load or applying some lithium grease.
chris7197789.50 |
| Bookmarks |
