      03-13-2016, 12:58 AM   #1
capvent
Drives: Z4 3.0i
**FOR RENT** MIS BMW E85 / E46 RTAB Tool - Low Deposit & Rent Fee
USD 25.00
BMW Rear Trail Arm Bushing Tool (RTAB) Rental
Amount to Deposit via PayPal: $75.00
Rental Fee: $25.00
Refund Upon Return (Renter pays for shipping back): $50.00
Rental Requirements:
1) Tool will be shipped via prepaid shipping with no cost to the renter
2) Renter will have 7 days in which to use the tool and it must be shipped on the 8th day (at renters expense)
3) If renter requires more time, renter will communicate with owner and an extension of 7 days will be granted at an additional cost of only $7
4) Renter is responsible for the tool while in their possession and must pay for any damage once returned
5) Renter will not hold Owner liable for any injury incurred while using the tool
BMW E85/E46 MIS RTAB Tool. You can use this BMW RTAB Tool (Rear Trailing Arm Bushing) to remove and install BMW rear trailing arm bushings.
FREE USPS Priority 2-3 day shipping to you with tracking included.
Rental will include:
(x1) BMW RTAB Tool
(x1) Threaded rod and bolt
* This MIS RTAB Tool will install BMW part numbers:
33326770786,
33322228153,
33326770817, and all other OEM E36/E46 rubber bushings, including M3.
* The Z4 has the same BMW part number 33326770817 for the rear trailing arm bushing as the E36 / E46 so this tool should work on the E85/E86 also.
Tips during use
-DO NOT USE power tools. You may strip the threads on the metal blocks and or the threaded rod.
-Use plenty of heavy weight oil on all threads, rod, and washers. Heavy weight oil is highly recommended in every use.
-Make sure rod and block threads are clean before every use.
-Lubricate the tool and blocks to prevent rust and corrosion with sprays such as WD-40.
PM me with interest to rent and I will post availability on this thread on the top page! Thanks.
      03-14-2016, 12:15 PM   #2
elerner61
elerner61's Avatar
171
Drives: '07 Z4M Roadster
Thanks for offering this. How have you aligned new RTABs/carrier before tightening them? When I last thought about this, I figured that before I removed the old ones I would mark the position of the old RTAB/carrier to the trailing arm (mark it on the carrier).
      03-14-2016, 09:20 PM   #3
capvent
Drives: Z4 3.0i
You have to mark the mounting brace with the position of the bolts before you take them off. I used a metallic Sharpie marker that worked great. Good luck!
      12-07-2016, 10:14 AM   #4
manydubs
Drives: 95 M3
I would like to rent this tool.
      12-09-2016, 03:16 PM   #5
capvent
Drives: Z4 3.0i
PM sent - thanks!
      02-15-2017, 03:56 PM   #6
capvent
Drives: Z4 3.0i
BUMP
      03-16-2017, 06:07 PM   #7
TangoMike
Drives: 2005 M3 Coupe 6MT
Smile
Hello,
I would like to rent this tool, if it is still available. Thank you for your time!
- TangoMike
      03-16-2017, 10:05 PM   #8
capvent
Drives: Z4 3.0i
Yes - PM sent. Thanks.
      04-30-2017, 11:51 AM   #9
capvent
Drives: Z4 3.0i
Tool back and ready for another rental! Thanks.
      05-13-2017, 01:52 PM   #10
Pratz
Drives: '95 325is
I'd like to rent this tool, if its not out.
      06-13-2017, 04:51 PM   #11
capvent
Drives: Z4 3.0i
Tool is back in and ready to rent! Thanks.
      06-20-2017, 04:51 PM   #12
capvent
Drives: Z4 3.0i
      07-26-2017, 04:45 PM   #13
capvent
Drives: Z4 3.0i
      10-08-2019, 09:28 AM   #14
mfridlyand
Drives: BMW M3 1999
RTAB rent
Is this tool still available for rent and will it work for 1999 M3 E36?
Thanks,
Mark
      04-14-2021, 09:45 AM   #15
elerner61
elerner61's Avatar
171
Bump on this. Capvent, is the tool still available for rent? Thx.
      03-20-2022, 03:03 PM   #16
ktmcelrath
Drives: 04 e46 M3
Tool rental
Is the E46 RTAB tool available for rent? If so, what is the soonest you could ship and from what state, assuming you're in USA.
      07-16-2024, 08:27 PM   #17
Archbid
Drives: BMW 330ci
Still available?
