05-05-2024, 05:01 PM | #1 |
Rep 22
Drives: 2003 bmw z4
Repaint faded z4 m steering wheel
Hey do you guys know what paint I should use to paint the e85M steering wheel from fade?
05-06-2024, 03:35 PM | #2 |
Rep 173
As my plastic coating was scratching off I disassembled the trim parts...used rubbing alcohol to remove the remaining coating (down to bare plastic)...and then sprayed them with SEM Products 15243 Satin Black Color Coat. Looks great! Almost, but not quite OEM look.
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android |
05-07-2024, 09:24 AM | #4 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
If you want professional results, do the following:
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
05-09-2024, 09:45 AM | #6 |
Rep 2,882
Looks great - How did you end up refinishing it?
Jays.-.beemah3.00 |
05-09-2024, 10:23 AM | #7 |
Rep 22
Drives: 2003 bmw z4
Thanks it was kinda easy, all I did was pull all the trim off and sand them, then I went to autozone and bought a special plasti dip (https://www.autozone.com/paint-and-b...&gclsrc=aw.ds) make sure you allow the plasti dip to warm up by putting it in hot water and when you spray make sure it’s thick or else you’ll get bad orange peel (when you spray it thick it will look glossy but also smooth that’s how you know you are spraying right). That’s pretty much it sanding was the most annoying part lol. But I liked how it came out also don’t fret if you get orange peel just peel it off and start again!!
XMetal1167.00 |
