02-25-2024, 05:12 PM | #1981 |
Rep 2,714
Isn’t Canada also getting the new B58?Didn’t you also confirm that the only exterior change would be the optional iconic glow kidney grille?Do you also see any new exterior colors for the 3 series?
02-25-2024, 08:52 PM | #1982 | |
Rep 1,447
02-26-2024, 06:45 PM | #1983 | |
Rep 3,440
The new colors will be the same that are being added on other models. I haven't yet seen any whose first appearance would be on a G2x model. |
02-27-2024, 04:42 AM | #1984 |
Rep 776
WTF....2435 kg curb weight for the G90 is 300+ kgs more than my F pace SVR (which is already a heavy car... even if "light" for being an SUV compared to others in its class).
///M3 Competition xDrive Skyscraper Gray - full black Merino
BMW G80 M3 Comp.xDrive 2022 + Jaguar F-Pace SVR v8 2022 + BMW F20 M140i RWD 2017 |
02-28-2024, 06:05 PM | #1986 | |
Rep 2,349
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
02-28-2024, 07:29 PM | #1987 |
Rep 3,440
MadBimmeRad7121.50 chris7197334.00 |
02-29-2024, 06:26 AM | #1988 |
Rep 1,422
An alternative take is the G90 weighs 52 lbs more than the Lucid Air Sapphire, which has a positively massive (and heavy) 118kWh battery, which allows it to have a 427 mile range despite having nearly double the power (1,234 hp) of the M5.
03-03-2024, 04:28 PM | #1989 |
Rep 2,714
I was looking at the specs for the Canadian MY25 M440i Coupe and it lists specific exhaust info in the standard specs.This is the info with the option code at the beginning,
1D1 Exhaust technology SULEV30 5AL Active Protection PMTECHN. When i did a google search it lists this as being some kind of exhaust particulate filter, https://www.avl.com/documents/10138/...0_Solution.pdf Does this mean that the new B58 TU engine for the US and Canada is now getting the exhaust particulate filter that Europe has had for quite a while now? I plan on ordering a new M340i this year so i am interested in knowing if the MY25 will come with the particulate filter.All the reviews i have read mention that it ruins the exhaust sound. Here is the Canadian ordering guide with the info if anyone is interested. |
03-04-2024, 04:33 PM | #1990 |
Rep 3,440
The top post now lists all planned versions of G45. The most notable part is what it doesn't include: there will be no 30x outside North America, or any diesel larger than 20d. BMW will likely push the hybrid as the sweet spot for Europe.
Llarry16022.50 |
03-06-2024, 07:19 AM | #1991 |
Rep 776
so.....the L6 diesel is phasing out officially. I'm expecting not to see a 330d or M340d again on the upcoming G50.
03-07-2024, 03:35 PM | #1993 |
Rep 2,759
Drives: 2020 M4 ZCP / 2023 X3 M40i
BMWBLOG says there will be next gen ICE M3, but M4 may be dropped.
https://www.bmwblog.com/2024/03/05/2...3-g84-planned/ |
chris7197334.00 |
03-09-2024, 09:46 AM | #1994 |
Rep 1,136
ynguldyn I’m now reading that the g87 LCI will happen in calendar year 2026. Is that what you’re seeing also? This would mean the M2 CS will not be based on the LCI.
Seems odd to have the M2 LCI a year after the 2 series LCI. |
03-10-2024, 01:44 PM | #1995 | |
Rep 3,440
First of all, the situation with G42/G87 proves that I should revisit previously posted information more often because what I'm seeing right now is not at all what it appeared before. In detail: - Non-US, non-China M240i RWD will soon be dead (summer EOP) - There are hints that the old B58 will not be US emissions compliant for MY2027, so US M240i could be dead at the end of MY2026 (I'm not seeing B58M2 in G42 anywhere - yet?) - Now, it would be logical to suggest at this point that MY2027 will be the LCI year, however, the EOP dates for other models extend way beyond that. US 230i goes to the end of calendar 2027. All other models, including G87 - to 2029. - At the same time, I do see a few unknown future models of G42. What this means: it is certain that there will be no LCI in 2025. However, there's no strong evidence of LCI in 2026 or at any other time either. |
03-11-2024, 07:13 AM | #1997 |
///M driver
16023
Rep 499
Drives: 2022 M3 6-speed
If I am reading your info properly, there is no G45 hybrid option for USA.
'22 G80 M3 6-sp Portimao Blue/Tartufo
03-11-2024, 02:22 PM | #1998 |
this is the way
18157
Rep 8,527
03-20-2024, 02:53 PM | #2000 |
Rep 3
Do you know if it is possible to tune the i4 as well? I have an i4 40e but don't like the speedlimeter on 190 km/h (for German highways).
03-20-2024, 03:57 PM | #2001 |
Rep 437
Tags |
future bmw, release date, upcoming bmw |
