01-28-2024, 03:54 AM | #1 |
Rep 2
Bubbles in coolant bottle BMW z4 e89
I've had zero issues with this car for 7 years... Until now.
A few week ago I was driving along and my z goes into limp mode with an overheating issue. I pull over and check the coolant. It had been leaking so I topped it up. On the way home it keeps throwing the overheating light and I had to stop and pull over. This part may be unrelated... The battery died. RACQ put a new battery in. It started, but shortly after the power would die completely when the car was turned off. Someone told me the seat modules often play up and could cause parasitic drain. Also the roof module can cause this, or an interior looking ght staying on. I pulled the fuses on all three. I put the battery on the trickle charger and charged it 3 times to fully charge it. Not the car starts fine and doesn't lose power instantly. So I'm guessing one of those modules has an issue. However, I started the car and ran it for a few minutes. I checked the engine and there is a strange noise coming from the m the front. Could this be the water pump? If it's stuffed it would explain the overheating: Then I took the coolant cap off (engine off) and water and bubbles are pouring out: Now, besides a blown head gasket (which everyone has said on my past cars has been 'the issue' and which never turned out to be the issue) what could the issue be? I suspect the water pump is gone? |
03-01-2024, 11:07 AM | #2 |
Rep 2
I would say that looks like Air in the expansion tank, if you have a leak and air is getting in you'd see some foam. When you topped it off what did you use? some colors aren't mixable with the BMW Blue.
If you have a leak air is getting in the system, which would cause you to overheat. You'll need to fix the leak and then bleed the system using the electric waterpump. IF the electric waterpump isn't working you wouldn't be getting the stream on your picture, also you'd havea CEL. I'd get it flushed once you've fixed it or do it yourself. Good Luck |
03-01-2024, 11:31 AM | #3 | |
Rep 688
I wouldn't drive the car again until you're sure, driving over heated can and will warp the head and cause a gasket leak and worse. |
03-01-2024, 11:33 AM | #4 |
Rep 688
I'll add that noise sounds like a diaphragm of some sort having pressure issues. There again could be combustion gas getting into the cooling system causing pressure.
03-01-2024, 06:51 PM | #5 |
Rep 202
Drives: BMW Z4C 3.0si 3 pedal
Have a test done for gases in the radiator. Will be able to tell immediately if you have a blown head gasket.
https://www.amazon.com/Block-Tester-.../dp/B06VVBSFTF Last edited by cbpip; 03-01-2024 at 11:19 PM.. |
