      08-29-2023, 06:54 AM   #1
ccav
Drives: 2007 Z4
After Market Radio Screen Flicker
I recently installed a Boss BCPA8 in my 2007 3.0i.
All went to plan with the exception that if the headlights are on the screen transitions between day time brightness to night time brightness settings. If the dash light level is lowered the screen stays on the day time setting longer (the opposite is true when I increase the dash light brightness setting).
Reviewing the harness there does not appear to be another signal wire. My question is, can I install relay- use the illumination wire as control and tap into the accessory wire as signal wire to the radio. In theory this will work but I also know BMWs are sort of touchy when it comes to electrical loads.
Any feedback on this or an alternate approach would be appreciated. I understand that removing the signal will also work but would like to hold that approach as a last resort.
Thanks
      08-29-2023, 11:54 AM   #2
Clearancediver
Drives: 2004 Z4
I’m curious if you looked up which radio set up (there are 3 and the “premium” choice isn’t compatible with non oem radio’s) you have. If you have a 10. Speaker system (there are 2) only the hi-if version is compatible.
Edit: If you have the high end premium system…. It will appear that it’s functional, but you no longer have all 10 speakers functioning, as the amp is no longer receiving a signal (via k-bus… you can look up the technical details) required. There are numerous articles accessible via google search on this issue.
Sent from my smart phone...
      08-30-2023, 07:00 AM   #3
ccav
Drives: 2007 Z4
Thank you for the input. I will focus my Google searches per your suggestion.
      08-30-2023, 07:24 AM   #4
ccav
Drives: 2007 Z4
I have the 6 speaker system, most obvious indication is the lack of the center channel on the dash. Also I did not note a degradation of sound “quality” when I swapped the unit.
Any thought about using a relay?
Thanks again for the help
      08-30-2023, 09:40 AM   #5
pungo
pungo's Avatar
961
Drives: Z4MC, X3-35i,525i, Corrado G60
Just so you know, the E85/E86 didn't offer an option with a "center channel on the dash"
Maybe the illumination uses PWM? If so, use one of the exterior light outputs on the LSZ or trigger a relay off one of them.
      08-30-2023, 01:20 PM   #6
ccav
Drives: 2007 Z4
Thanks
I am attempting to locate a low output relay. PAC TR4 is showing it is good down to .8 volts, just checking to ensure it can handle 12v input.
Appreciate the info
