04-03-2023, 03:09 PM | #177 | |
dances with roads
5023
Rep 4,121
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
86Zed964.50 |
04-05-2023, 03:37 PM | #178 |
Rep 50
Great Work! I have followed this the whole way.
I am wondering if you have a preferred brand of foam for the cannon, or is it like any other soap for washing a car (personal preference)? Not sure if it makes a difference, but I had the paint corrected and ceramic coated last year. Tye |
04-06-2023, 05:07 AM | #179 | |
Rep 802
2008 E86 M coupe
04-19-2023, 07:09 AM | #180 |
Rep 583
well done grannyknot!
this was such a deep-dive i don't know where to begin....incredi-hours and acumen spent to "refresh" this marque - tell us about the maiden launch and voyage - any special local places you took her? are you keeping her for a bit before moving on to the next challenge? |
04-19-2023, 03:20 PM | #181 | |
Rep 802
Still have to refill the AC system and get a proper wheel alignment. Josh at Severn sent me the final Tune to load and just took it out last weekend for a 2 hr. rip to test it out, so much better performance than before. I don't just mean more power, the consistency, the smoothness, the throttle response all feel better than stock. Just my opinion but the Severn tune is worth every penny, Josh will work with you until you are happy with the results. It might just be a placebo effect but knowing that every wearable part is now new makes the driving experience more enjoyable. Feels like a new car.
2008 E86 M coupe
04-19-2023, 04:11 PM | #182 | |
Rep 583
a 2 hr rip is certainly a shakedown....and the increased performance/driveability pegs out the joy-o-meter. |
07-29-2023, 06:21 AM | #183 |
Rep 802
The coupe is running very well now, I just found the centre section for the exhaust system on ebay and snapped it up.
I have been looking for this piece since I bought the car, the PO had the original mufflers replaced with Rouge Diablo's which sound great, very happy with them but the hack who did the work cut one of the rear pipes too far back and replaced it with a smaller dia. plain steel pipe. Also, p/u up a new battery cable with explosive disconnect from one of the members here on the forum. Hoping it will finally fix the airbag warning light. This is the ebay piece that is on it's way.
2008 E86 M coupe
wdb5022.50 E93Seattle (Racerbruce)806.00 |
07-29-2023, 07:57 AM | #184 | |
Rep 12,635
Garage List E86 Z4 M [10.00]
07-29-2023, 04:44 PM | #185 |
Rep 802
I didn't pay his asking price
2008 E86 M coupe
3002 tii2387.00 E93Seattle (Racerbruce)806.00 |
07-30-2023, 06:22 AM | #186 | |
Rep 583
Purchased my 07 Z4MR in early 2010 and immediately installed Rogue Engineering Diablo mufflers - they were still on the car when I sold it in late 2022 and no rust, no fitment issues, no leaks and sounded as good as day one. |
grannyknot1000.50 |
04-21-2024, 12:03 PM | #187 |
Rep 802
I replaced the main battery cable with the new one and the irritating airbag light on the instrument cluster is gone, YAY.
But the old one doesn't seem to have any problems that I can find So there is nothing left to do but try and blow the disconnect charge, anyone know what kind of a signal it requires to set off the fireworks? I tried 12vdc to the 2 wires coming off the top of the charge but no luck.
2008 E86 M coupe
04-21-2024, 12:53 PM | #188 |
Rep 1,017
Typically, MGG devices require 1.75a of current and 12V for at least 5ms.
Maybe yours is bad and that is the cause of your DTC. There could be something wrong with it internally. you can measure resistance and it should be 2 - 2.2homs. just check resistance on the MGG terminal wires, no need to blow it out just to check if it works, unless you want to do it just for fun. |
