Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > USA - California
      06-13-2022, 06:58 PM   #1
tenfootelvis
Drives: 2006 Z4 Si Roadster
Mechanic/Shop for Z4 top SF Bay Area?
My top mechanism won't work properly. I can hear the pump/motor working and it will open but it seems to not generate enough pressure to raise the top at all. Not sure if it's maybe a pump problem or maybe a hydraulic leak. My normal shop in Walnut Creek won't work on the top.
Does anyone have a recommendation for a good shop that works on tops? Ideally in the SF EAST BAY area. Thanks!
      04-04-2023, 06:52 PM   #2
WAGMI
Drives: '08 Z4MR
Did you ever find one?
      06-08-2023, 01:25 PM   #3
gartnert
gartnert's Avatar
Drives: 2004 Z4 3.0i
I can help
I am in San Jose, just repaired my top. the hydraulic hinges had a seal break so had to replace hinges.
      07-23-2024, 08:00 PM   #4
aerostarlegacy
Drives: Z4M Roadster
I know a guy
I know a guy that has some of the special tools to do this job. He's not doing the actual job anymore, but may still rent out the special stand (which is totally awesome) and give advice over the phone at reasonable rates.
I have middling mechanical skill (replaced axles, radiators, waterpumps successfully. Failed at rebuilding vanos and ac compressor.) and I think it's a job that can be done by someone at my skill level.
Tags
mechanic, shop
