06-09-2020, 07:18 AM | #1 |
Rep 399
KW V3 Installation help
Guys need help with KW V3 Installation on my Z4mc
Installing last night rear springs and stuck with following: KW Instruction stating that upper rubber pad needs to be removed. I have hard time to believe that metal to metal connection in suspension is good Idea . Thanks in advance |
06-09-2020, 11:39 AM | #2 |
Rep 433
metal contact definitely not good. I just installed a set of ST X which is basically same as KW V1 and the rear perches come with its own rubber pad. You just re-use the bottom rubber pad. Is it not the case with V3? Did you buy the set used or new?
06-09-2020, 08:56 PM | #3 |
Rep 1,373
You don't need the rubber pad. No suspension set up that is more to the serious performance side of things will have a spring pad in the rear. In addition KW knows their shit so if they say no spring pad i would not go against the way they say the suspension should be set up.
07 Z4 M Coupe AW/IR |
06-10-2020, 06:49 AM | #4 |
Rep 399
yes it was used, and I think I already figured out that they need rubber ring, I end up of Installing same style thin rubber pad as factory one at the bottom, that's what mechanic suggested me
06-10-2020, 11:53 AM | #5 | |
Rep 433
F360C, yes KW do know their stuff and here's the pic of the rear spring perches from KW V3 for e85/e86 which shows the rubber pad in question. It is exactly the same as other KW/ST suspensions including V1 and ST X variants. |
AK72286.00 |
08-25-2020, 01:37 PM | #7 | |
Rep 57
09-16-2020, 08:56 AM | #8 |
Rep 16
Here is the information out of the official parts approval document:
10-40 mm I don't think that you can as low as you want to ... In my opinion that would not be possible either, the spring rate would not be high enough to have enough free space @ high compression (between wheel and fender) with the stock V3 springs ... greetz Enzo |
