08-07-2020, 10:08 PM | #1 |
Rep 5
BlueBus Install in E86 Z4M
Hello everyone!
I've had a Z4M for many years and have used the AUX cable for playing music, but I saw the BlueBus (https://www.bluebus.dev/) early this year so I ordered one for the car. The BlueBus handles phone calls and music which is what made it appealing to me. My question is relating to the amplifier on these cars. On other cars (E39), the amp has a coaxial plug which is used for digital audio. I did not find a coaxial plug on the amp in my Z4M. I looked up my audio system in the build sheet and found that it is HIFI SYSTEM PROFESSIONAL (S677A). So my question before I button up everything in the trunk, is the pre-wiring (3 pin cable and 6 pin cable) for the CD Changer the best bet for audio quality? Is there no way to use a coaxial connection for better quality? I saw a coaxial cable dangling above the TCU, but it didn't seem to do anything. Thanks! |
08-08-2020, 10:56 AM | #3 | |
Rep 5
HIFI LOUDSPEAKER SYSTEM (S676A) HIGH DEFINITION RADIO (S653A) Just looking for clarification. |
08-08-2020, 09:26 PM | #4 |
Rep 978
We don’t have coax for the CD changer, we have the 6 pin connector, and that is what you use for the bluebus.
I have your same audio options (S677A), my car does not have Nav nor the CD changer, but I do have the prep option. My bluebus is still 2 months away |
08-10-2020, 09:18 AM | #5 | |
Rep 5
Also, are you saying that all Z4Ms don't have coax for the CD changer? Just curious what determines that. Also, it was kind of a pain to rip apart the trunk to get to TCU and pre-wire. |
08-10-2020, 11:40 AM | #6 |
Rep 425
S677 is the top end Carver system. Use the left side radio buttons to "click thru" to the DSP options to confirm you have the proper radio installed.
I have that system and I ran my vin thru a decoder to confirm my build. I also have the coaxial cable input to the amp... which I had to replace. Considering I had to pay over $1K for the silly thing you can be sure I know which system I have as the other non DSP amp is less than half that price.
Sent from my smart phone...
08-10-2020, 01:02 PM | #7 | |
Rep 978
I am debating using the BB for calls or keep my TCU, which is almost useless as quality is very poor anyway. If you go to the NAM3 forum there is more info there and I think you can tune mic volume to reduce echoing |
koruptor32.00 |
08-16-2020, 01:33 AM | #8 | |
Rep 57
08-17-2020, 02:36 PM | #10 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I find this very interesting! I've been using GROM for years but I like the idea of an open source product with a UI.
Questions for those in the know, or who have installed this:
2008 Z4 3.0si Coupe
08-23-2020, 03:31 PM | #11 | |
Rep 5
For question 1, I don't know that I verified this, but I imagine it should work (the comfort settings). I believe I remember seeing it in the setting menu when setting it up. For question 2, I believe that answer is no, you cannot connect your phone via USB. Honestly, it works great because it connects every time I get in the car and it makes the car feel more modern. I just need to install the phone holder I have so I can have Android Auto open while driving. There was one issue that I noticed while using it with the my E39. When using navigation on the phone, the first second or two of every navigation message was cut off. So I would hear "Lincoln Ave" instead of "Turn left on Lincoln Ave". Haven't had a chance to diagnose if it's a BlueBus issue or a phone issue. Using a Pixel 4. |
koruptor32.00 |
08-23-2020, 07:58 PM | #12 | |
Rep 162
Thanks for sharing! It's been years since I've had an Android phone but I may have had the same issue when I was running Google Maps on Android with GROM. So I'm curious if it might be an Android issue rather than a BlueBus issue. Either way, this is good to know.
2008 Z4 3.0si Coupe
08-25-2020, 03:01 PM | #13 | |
dances with roads
4773
Rep 4,102
08-25-2020, 03:53 PM | #14 |
Rep 50
I also have this installed on my car, I love everything it can do. My only wish is that the navigation screen does not pop up every time I touch the forward/backwards button on the steering wheel. I wish the screen would stay down unless I press the button to raise it. That has nothing to do with the bluebus though, it did this before when everything was stock, however I'd use my phone to skip songs which would not trigger the screen to open.
I also love that it enabled the "comfort blinker" and it'll lock the doors at a certain speed, and unlock when I turn the key off. 10/10 recommend. |
08-30-2020, 08:21 PM | #15 |
Rep 79
Drives: E85 ZRMR (sold), E46 M3 Cabrio
I ordered a BlueBus for my E85MR without navigation. I was told that delivery would be in October. I’m a little apprehensive about the installation. But I can’t wait.
Doug |
08-31-2020, 05:16 AM | #16 |
Rep 57
Please let us know how the installations goes, I'm interested in ordering one too but i'm not sure where does it connect to.
08-31-2020, 04:07 PM | #17 | |
Rep 50
You'll access it from in the trunk. Granted I installed this on a coupe and not a convertible, but I'm sure the cables are in the same location. After removing the carpeting/trim panels, locate the amp. I removed my amp and found the cd changer wires tucked right behind it. It's literally plug and play. I secured the bluebus with double sided tape, and put everything back together. The coax cable doesn't seem to fit/work for our cars. At least it did not on mine. |
09-01-2020, 10:45 AM | #18 | |
Rep 208
Drives: 08 Z4 M Coupe
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
09-02-2020, 11:15 AM | #20 | |
Rep 50
I removed a little more than I needed to b/c it was my first time doing it. However yes, you must remove the floor covering, battery cover, and back wall piece. The back wall piece has a plastic clip that connects it to the side pieces, so you do have to loosen the side pieces a bit, only where the 2 connect. I also had to remove the plastic trim panels that sit right next to the side window. The middle trim plastic piece at the top does not need to be removed. I also removed the battery to gain access to the strap that secures the amp in place. You do not need to remove the metal bracket that the the Amp is strapped to. The electric box to the left (not sure the correct name) does not need to be removed. I moved the amp only to gain access to the 2 loose wire connections you'll need to plug into the blue bus. |
bwright657257.50 |
09-02-2020, 11:16 AM | #21 |
Rep 50
09-03-2020, 03:55 AM | #22 |
Rep 57
