      06-25-2020, 08:57 AM   #2135
Almuliman
Drives: 2013 LMB 6MT 128i
Noob question (probably): What's the rear? I mean, upgrade (presumably , expected results, vendor / manufacturer?
Originally Posted by F360C View Post
Got her a new rear end and some more power
      06-25-2020, 01:43 PM   #2136
F360C
Drives: E86 S54
I probably should have added more context... I took the rear end out and stripped everything down to get rid of any rust and repainted it. I also replaced ALL the bushings in the rear end. The upgrades were as fallows:
  • Turner Motorsport upper control arm monoball bushings
  • Turner Motorsport monoball rear trailing arm bushings
  • Turner Motorsport rear camber arms
  • CMP solid rear subframe with a 5mm roll center correction
  • New OEM upper and lower outer ball joints
  • Ground control weight jacker rear spring mounts
Basically the goal was to replace everything in the rear end I could that would lead to better handling. The solid rear subframe bushings were the ones I wanted to do the most. As these will lead to great benefits in handling while according to everybody that has them lead to little or no increase in NVH. As a side benefit a couple of the parts (the weight jackers and rear camber arms) make it a bit easier for me to do alignments/corner balancing.
07 Z4 M Coupe AW/IR
Almuliman483.50
      06-26-2020, 01:22 PM   #2137
Naiart
Drives: E85 Z4M
I installed a new third brake light (old one was cracked), stubby Mini antenna for the aerial, and replaced the driver's side door jamb weatherstripping since it was torn. Also got an oddments tray and a new clip on the air filter box to replace the one I broke (not sure how to put in on). Also, my power top stopped working so I ordered a new pump and will be looking at mucho $$$ to fix it..
      06-26-2020, 01:35 PM   #2138
No_Dominion_2
AKA No_Dominion
No_Dominion_2's Avatar
Drives: 2007 Z4M
Finally picked up an oddments tray after seeing people on here putting them in. So nice to have that button panel gone and something useful in its place. $1& from getbmwparts.
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune
Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces
H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals
wdb4721.50
      06-26-2020, 03:27 PM   #2139
wdb
dances with roads
wdb's Avatar
4722
Have you located any oddments yet? I'm having a heck of a time.
      06-26-2020, 03:38 PM   #2140
No_Dominion_2
AKA No_Dominion
Drives: 2007 Z4M
No, for the time being I'm simply using strangements and weirdments.
wdb4721.50
Almuliman483.50
Efthreeoh17306.00
      06-26-2020, 07:06 PM   #2141
No_Dominion_2
AKA No_Dominion
Drives: 2007 Z4M
I got inspired by Beedub from the video he posted and decided to order some of these custom cut floor mats from Diamond Car Mats about a month ago and was stoked to install them when they arrived today.
Quality is top notch, they fit perfectly, and look great. Simple to install and seem to be very secure.
Definitely a great and inexpensive ($100 shipped) way to update/refresh the interior!
3798j11409.00
      06-26-2020, 08:50 PM   #2142
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Got some character now that I got rid of that plain jane NON M hood
3798j11409.00
      06-29-2020, 08:47 AM   #2143
F360C
Drives: E86 S54
Whoaaa! What hood is that?
07 Z4 M Coupe AW/IR
      06-29-2020, 02:53 PM   #2144
No_Dominion_2
AKA No_Dominion
Drives: 2007 Z4M
That looks to be the Slek hood, verrrry attractive, indeed.
Makes me sad that I only got my new rotors installed... 😂😂😂
      06-30-2020, 02:13 AM   #2145
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Makes me sad that I only got my new rotors installed... ������
Thanks! You are correct No_Dominion_2 it is a SLēK Design CF vented hood
      06-30-2020, 10:35 AM   #2146
2282
New wheel sensors, hope it’ll address the ASC/DSC codes I got recently because relating DSC module would be a real kick to the balls.
      06-30-2020, 11:44 AM   #2147
wdb
dances with roads
wdb's Avatar
4722
What were the codes? I had 5DF0 and 5DF1, wound up having the DSC module rebuilt by ModuleMasters.
      06-30-2020, 02:18 PM   #2148
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Eventuri Intake
PLCZ4MC79.00
wdb4721.50
      07-01-2020, 11:50 AM   #2149
2282
005E14 among others which I can’t recall at the moment...
      07-02-2020, 12:09 PM   #2150
bwright657
bwright657's Avatar
258
Drives: 08 Z4 M Coupe
Got a Strömung Exhaust from one of the Z4 Facebook groups. The improved looks alone and reduced scraping are already enough for me, but the sound improvement is great. I think it pairs perfectly with my Eventuri intake.
Almuliman483.50
      07-02-2020, 04:28 PM   #2151
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Those tips look larger than you standard Stromung tips for our cars!
      07-02-2020, 09:12 PM   #2152
bwright657
bwright657's Avatar
258
I took some measurements and looked at alot of pictures, these are the same 3 inch tips and fill out the bumper the same as others. Maybe it's the side by side comparison exaggerating things?
      07-02-2020, 10:52 PM   #2153
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Perhaps it's just the angle of your picture, but they sure fill out the bumper similar to my 83mm Eisenmann tips.
kaybat125.50
      07-02-2020, 11:32 PM   #2154
pyshin
pyshin's Avatar
Drives: 97c2
Prepaid for my 1st Blackstone oil analysis; eager to set a baseline for many future analyses.
      07-03-2020, 05:16 AM   #2155
coyote82
Hungary
Drives: E89 Z4 3.0, F36 440i GranCoupe
Just purchased 2 M-sports seats to my E89 to replace my basic seats. Both the old and new seats are heated and manually adjusted. The only concern is that I bought the new ones from a right-hand drive car, planning to install them into my LHD.
Should I expect any issues? Or are they plug'n'play?
BMW Z4 3.0 2009
BMW Z3 1.9 1996
BMW 440i Gran Coupe 2017
      07-03-2020, 11:23 AM   #2156
belcom
belcom's Avatar
Drives: '18 540i, '06 Z4si, '07 Z4MC
Wheels/tires. Have to adjust height again as it looks somewhat different after going from 18 to 19.
wdb4721.50
3798j11409.00
