      11-03-2019, 07:43 PM   #1937
deemo319
deemo319's Avatar
Drives: BMW
Originally Posted by Our03z4 View Post
Originally Posted by deemo319 View Post
Had four new tires mounted and balanced by mobile installer.
Pretty cool! How much extra did it cost to have them come out? I have a 4 vehicle fleet that I'm constantly putting tires on and would be nice to not sit at a tire store for once.
I think it was $145 for all four tires to be mounted and balanced.
He has a really good setup with everything inside of the truck and the two portable air jacks he has are straight dope.
      11-08-2019, 12:12 AM   #1938
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
A Seat
3GFX722.50
      11-08-2019, 01:23 AM   #1939
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Originally Posted by TRiCC View Post
[img]
View post on imgur.com
[/img]
A Seat
That looks great! What'd your setup for mounting? Slider? does it rub at the door cards? Spg Profi or?
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
      11-08-2019, 02:09 PM   #1940
Jiaim
Jiaim's Avatar
77
Drives: 2007 PY Z4 3.0SI
New legs !
Out with the old :
In with the new :
      11-09-2019, 10:35 AM   #1941
SlikM
SlikM's Avatar
Drives: '08 BSM/Blk M Coupe
Bought my M another.....M to keep it company
XMetal1136.00
      11-09-2019, 02:25 PM   #1942
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Brey krause/oem slider brackets, profi spg xl. Got more than ~inch clearence on the door panel
      11-09-2019, 06:34 PM   #1943
3002 tii
3002 tii's Avatar
2286
did your stock seats have manual or power sliders?
Follow for latest mods
      11-10-2019, 10:55 AM   #1944
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Power seat sliders
      11-24-2019, 06:34 PM   #1945
thrak410
Drives: 2004 Z4 Roadster
Well, bought a while back, but finally installed:
H&R front/rear sway bars (and made steel reinforcement plates for the front)
slotted & cross drilled rotors all around
ceramic brake pads all around
oil change kit from ECS
Lemforder FCABs
Skyer convertible side covers
Also, after many months of trying to track down the source of a 'clunk' coming from the front, I discovered the reinforcement plate that covers the oil pan had 7 of 8 bolts loose, and the 8th was missing! :O Everyone says to check the strut tower braces, but my issue was underneath.
Can't wait to drive it this week!
wdb4732.00
      11-25-2019, 09:48 AM   #1946
cbecker33
Drives: Z4 M Coupe
Oddments tray
Stock floor mats
Shift knob
      11-25-2019, 09:54 AM   #1947
3002 tii
3002 tii's Avatar
2286
Originally Posted by cbecker33 View Post
Oddments tray
Stock floor mats
Shift knob
I did those same 3 pieces (diff knob though) during summer.
Ordered some custom exhaust tips that fit over the stockers. Also bought new set of OEM motor mounts.
      11-25-2019, 10:10 AM   #1948
KevinC
your average JAMF
KevinC's Avatar
Everyone with the old BMW Assist panel on the console should ditch it for the oddments tray. BMW Assist as it was in 2006-2008 is no longer functional - it utilized the Verizon analog network, which has been shut down for years now. Might as well make use of the space with the tray, which is readily available and not expensive.
'21 M2 Comp
'19 Golf R
      11-25-2019, 10:31 AM   #1949
cbecker33
Drives: Z4 M Coupe
I did those same 3 pieces (diff knob though) during summer....
This is the only shift knob I will now own. It's weighted and has a delrin cover (won't scorch your hand in the summer) that can be easily changed for different shapes. I bought one for my GT350 and put an (almost) identical one in the Z4M.
I tend to put my elbow directly on the clear plastic cover (and its little tab) as I lower myself into the seat. It was bound to break.
      11-25-2019, 11:02 AM   #1950
rsutoratosu
Drives: Z4 3.0i
FINALLY got my lazy self to run a hardwire kit from fuse box through center trim and up (and exiting) the center console to power my GoPro. Timing couldn’t be better seeing how the track season is pretty much done lol.
I just bought a fuse kit also for dash cam. Which fuse # did you end up using ? is it the on with ignition ?
-Roranji
      11-25-2019, 11:17 AM   #1951
thrak410
Show us your seats!
      11-25-2019, 11:37 AM   #1952
cbecker33
Drives: Z4 M Coupe
Originally Posted by thrak410 View Post
Show us your seats!
3GFX722.50
      11-25-2019, 12:41 PM   #1953
thrak410
Wow! How comfortable is that? Is it mainly a track car?
      11-25-2019, 02:04 PM   #1954
cbecker33
Drives: Z4 M Coupe
More comfortable than it looks. I just picked it up a few months back and have not taken it to the track. Currently I drive it on the street (although the seats are quite hot without AC during the summer months).
      11-25-2019, 02:44 PM   #1955
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Do you have more info on those? How is fitment to the car and to the passenger?
      11-25-2019, 02:57 PM   #1956
cbecker33
Drives: Z4 M Coupe
There is plenty of room on the sides though the headrest will rub the headliner if pushed all the way back. I am 6'1" and do not have the seat all the way back at my preferred driving position.
I believe these are the seats.
3GFX722.50
      11-26-2019, 03:47 AM   #1957
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
My Recaro Pole Position Seats
3GFX722.50
3002 tii2285.50
      11-27-2019, 08:05 PM   #1958
3002 tii
3002 tii's Avatar
2286
"Shorty" OEM valve stems... factory originals are 56mm but replacing with 43mm (p/n 36146792829 for anyone wondering)
