08-20-2018, 11:38 PM | #507 |
Rep 365
AmanYasirA - thanks for your feedback. What wheel specification do you run with the 255 tyre?
Thanks again M-Cast. I think those alignment settings and wheel specs will be a bit much for me but the car does look awesome. |
M-Cast711.00 |
11-12-2018, 06:35 PM | #508 |
Rep 382
Hello I am new here. I installed these 260m(euro spec) on my new to me Z4M today. Stock suspension, got about -1.75 of camber in the front with the stock pins pulled. Running 235/40/18 and 265/35/18 Conti extremes. Absolutely no rubbing. I'm not totally in love with the look but they are wider and lighter than the OE wheels.
mr_z4mc1m_oz273.50 |
05-04-2019, 07:41 PM | #509 |
Rep 17
Hello all, being a recent 2007 z4mr owner, I would like to change my original wheels with Beyern 18". With stock suspension and everything else, could I use the following ?
front 18-8.5" et30 with Conti Extreme contact Sport 245-40-18 rear 18-9.5" et 20 same tires 275-35-18 Will that fit without any modifications? Thanks. |
05-05-2019, 09:21 AM | #510 |
Rep 431
Adding my new track setup here as a data point for others that might be looking to do the same.
Square Setup: * Apex ARC-8 18X9.5 et35 * Optional 5mm rear spacer * 275/35/18 Hoosier R7 or * 275/35/18 BFG Rival (both fit and run very wide) * Camber: F -3.4 | R -2.4 * Front fenders Rolled * Spring Type: Linear (JRZ/MCS) — front fitment may vary if using conical suspension like KW
cbryant5143.00 |
05-13-2019, 08:18 PM | #511 |
Rep 4
Hey guys, needing some confirmation on tyre sizes for my new wheels on the Z4M Coupe if at all possible. Have read through every page of this thread and no one has the exact setup I am looking at.
Basically I am wanting to know what the widest front and rear tyre I can run is without experiencing any rubbing issues on both standard suspension and also Eibach Pro springs. Would 19x8.5 ET35 with 245/35/19 fronts and 19x9.5 ET22 with 275/35/19 or 285/30/19 rears work? Wheels are Apex ARC-8. Thanks in advance! Last edited by rsrider; 05-14-2019 at 12:25 AM.. |
05-14-2019, 12:43 AM | #512 | |
Rep 2,931
05-14-2019, 02:10 PM | #513 | |
Rep 515
05-14-2019, 03:53 PM | #514 |
Rep 2,931
05-14-2019, 09:48 PM | #516 |
Rep 4
05-15-2019, 12:12 AM | #517 | |
Rep 2,931
245 x 0.35 = 85.75 mm sidewall 275 x 0.35 = 96.25 mm sidewall 275 x 0.30 = 82.50 mm sidewall 285 x 0.30 = 85.50 mm sidewall |
05-15-2019, 12:26 AM | #518 | |
Rep 4
05-29-2019, 09:45 PM | #519 |
Rep 4
Well I had the wheels fitted and they look amazing (in my humble opinion).
Went for 245/35 fronts and 275/30 rears. Tyres are Dunlop SP Sport Maxx 050+ and we have no rubbing at all even on full lock. Very happy. Thanks for the help! |
06-21-2019, 07:05 AM | #520 |
Rep 709
Drives: 06 Black Sapphire Z4MR
Finally joining the thread
Volk OG TE37 18x9.5 front, +28, +5mm spacer, 245/40-18 RS4, -2.5 camber 18x10.5 rear, +30, +12.5mm spacer, 275/35-18 RS4, -1.8 camber
Revolution of our Times
I will return to the track, one day. |
06-24-2019, 03:51 PM | #521 |
Rep 223
When I was selecting wheels / tires, I created this spreadsheet to tell me what the difference would be from stock fitment - basically so that I could use a tape measure against the stock tires / wheels to determine clearance on the inside / outside top of the wheels. Sharing here in case others find it useful too.
06-28-2019, 09:24 PM | #522 |
Rep 12,635
Garage List E86 Z4 M [10.00]
New track setup:
Apex EC-7 18x9 et30, 18x10 et22 Michelin Cup 2's 245/40 and 265/35-18 No spacers Slightly lowered on GC singles (maybe 1/2" from stock) running -2.8 up front and -2.0 rear. I can probably go wider/lower but first want to see how it works on track. I've had instances where clearance wasn't an issue on street but those hard compression dips on a road course led to rubbing. I know race silver is not the most unique but really like how it accentuates the aggressive spokes. Last edited by 3002 tii; 06-28-2019 at 09:31 PM.. |
08-15-2019, 05:45 PM | #524 |
Rep 7
love how the TE37s came out!
09-27-2019, 04:49 PM | #525 |
Rep 6
Rays Volk Saga
So cant get hold of 35 and 22 offsets for 18" volks anymore so would be great if someone here can help me to confirm these will fit;
18x8.5 ET36 5x120 18x9.5 ET20 5x120 Thinking of running 245/40/18 and 275/35 on stock suspension. |
09-27-2019, 05:17 PM | #526 |
Rep 1,548
that's a quite safe/standard setup. Depending on what kind of tires you run, they shouldn't rub at all.
FB Group-- > fb.com/groups/z4group Instagram --> @Skyermotorsport FB Page-- > fb.com/Skyermotorsport |
09-27-2019, 05:52 PM | #527 | |
Rep 6
09-27-2019, 06:28 PM | #528 | ||
Rep 1,548
I have ran 275 & 10 width et20 at the rear with PSS tires. They rub slightly at extreme conditions on OE setup.
