11-09-2018, 04:19 PM | #1 |
Rep 94
Improve 1 -> 2 shift
Hey everyone - just put my z4mc away in storage for the winter, which means I can start plotting changes for spring.
Current state is bilstein dampers, eibach prokits, AFE intake; Everything else is stock. My goal is streetability, with probably 4 road race track days per year on a short local track that I'm guessing would top out in 4th, maybe 5th... The first thing on my list is that 1 -> 2 shift, which is... tough. I don't have any complaint with the length of the throw, but I'm curious as to what experiences people have changing out various parts of the shifter assembly, and their effect on shift quality. Difficulty: I know relatively little about the shifter assembly. So... (1) There's multiple SSKs kicking around - who has experience w/ what? EDIT - just saw the very detailed autosolutions SSK thread - good impressions that sound in-line with my goals - precise shifting, not much change in throw. (2) Can anyone comment on the UUC DSSR? (3) I've read talk about replacing various bushings with Delrin / Turner / ECS parts - but I've never seen a breakdown of the various bushings, what they are, and why replacing any particular one with a solid piece would be beneficial - is there a resource out there that someone could point me too? Note - race solutions like the CAE shifter or Jafster knob are overkill for me - casually track days and daily driver summer duty are my main things. Last edited by winnipegz4m; 11-09-2018 at 04:57 PM.. |
11-09-2018, 07:57 PM | #2 |
Rep 1,031
I havent changed the shifter assembly but I found that when I changed the motor mounts (vibra tech, i think is the name) it made a huge difference in keeping the engine and transmission in line for shifting, thereby reducing the slop of going from first to second. Another good change was the transmission fluid. Went to Royal Purple (recommended weight, dont remember anymore) and that helped smooth it out even more.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
11-09-2018, 08:54 PM | #3 |
Rep 94
Thanks for sharing, @mirko - that's the type of insight I was hoping for - how did the motor mounts affect daily driving comfort?
EDIT - how about these "tunable" mounts: https://www.bavauto.com/bmw-motor-mount-pff5-4650bx2 Last edited by winnipegz4m; 11-09-2018 at 09:19 PM.. |
11-10-2018, 02:50 PM | #4 |
Rep 1,031
No issues with daily driving. From memory there was maybe a tiny bit of NVH but not much. Now with headers, xpipe and exhaust I wouldn't even notice a difference! lol
For track use having the engine not pivot around in the front really helps keep the front end planted, or more predictable. My factory engine mounts were still in good condition, actually still have them so any change wouldn't be too huge for NVH or engine sloshing around but tightening it up did help keep the 1-2 shift more consistent. no idea about tune-able mounts. they are priced more or less the same as vibra tech and I think those are fantastic. Have heard same for people I know that have them installed.
11-10-2018, 09:44 PM | #5 | |
Rep 3,004
Bilsteins & Eibach Pro Kit Springs
Bilstein shocks and Eibach Pro-Kit springs are awesome....I'm very pleased with this upgrade.
Racerbruce
11-11-2018, 10:50 AM | #6 | |
Rep 211
Drives: 2007 BMW Z4M Coupe
Definitely change the motor mounts. Again the Vibra-tech seem to be the way to go. I can't feel any difference when it comes to transfer of vibration to the cabin. I would add also transmission mounts since you are going that way. And since you'll be under there check the giubo for cracks and wear. Cheers |
11-11-2018, 08:54 PM | #7 |
Rep 94
GPower - thank you - is this the Vibra-technics part?
https://www.vibra-technics.co.uk/bmw...l_engines_only |
11-12-2018, 09:04 AM | #8 |
Rep 264
There are a lot of ways to tackle the shift feel in our cars. The cheapest and easiest would be a shift knob change. It is amazing how much of a difference a shift knob makes on our cars. (Shameless plug for my MANY reviews of shift knobs thread https://www.zpost.com/forums/showthread.php?t=1492392)
CDV mod or delete and fluid change (Royal Purple Sychromax for me) would be next. I too noticed a difference with these changes. Both are fairly easy for a humble DIY'er to do, and a shop shouldn't charge too much for either service. Next would be both engine and transmission mounts. Limiting the slop with better mounts improves shift feel even more, however with a minor trade off in NVH. I went with the VibraTechnics Road mounts and Rogue Engineering transmisison mounts. Small NVH increase, however definitely tolerable most of the time. I will note that if you live anywhere that gets under 30 degrees Fahrenheit and you drive your M, the VT mounts make the car shake a bit and be loud until they warm up from engine heat. This is a more involved DIY and unless you are mechanically inclined, have a shop do it. Finally, new shifter assembly. I went with the Autosolutions SSK and it is VERY different. Eliminates nearly all of the slop, and feels almost like a gated shifter. I will note your shift knob choice will make a HUGE difference here, depending on your shift feel preference. Again, this involves some more advanced DIY skills (dropping exhaust, drive shaft, etc) and if you are not so inclined, have a shop do it. If you are considering a DSSR, do it at the same time otherwise you will be doing this job again! At the end of the day, I have found the above mods with the Jaffster delrin shift knob from bimmerworld is just amazing. The best shift feel I have felt in my car by a long ways. No notch, period. However, since the Jaffster kinda looks like a simulated phallus, I run the weighted OEM style knob for daily use, which provides about 80-85% of the shift feel provided by the Jaffster, with minimal notchiness. Caveat here. Even after all of these mods I still occasionally 1-2 grind at an autocross. It has lessened the occurrences for sure, but it still does happen. At the end of the day, all the modifications in the world will not fix a driver who has an impatient left foot!
11-12-2018, 11:59 AM | #9 | |
Rep 211
11-18-2018, 08:19 PM | #10 |
Rep 94
Let me ask a bonus question - is it recommended to change transmission mounts without changing the motor mounts? I'm imagining if you changed one without the other, it would place stress on the changed mounts... i.e.: if you limit the motion of one part of the drivetrain, you should limit the motion of all parts to a similar degree --- thoughts?
11-19-2018, 10:38 AM | #11 | |
Rep 211
I tend to collect parts before I put them all on the car. But that's just me. It's a long winter start prep'ing for spring |
12-06-2018, 05:24 PM | #12 |
Rep 94
Just to close this off - I ordered an Autosolutions SSK and RE Neoprene Transmounts. They'll go in April and I'll post my impressions shortly thereafter.
Cheers and thank you for the advice, everyone! |
