05-26-2018, 02:44 PM | #1 |
Rep 24
HELP! Has anyone replaced their Vanos Filter?
I just did an oil change and was replacing the Vanos filter. Watched an ECS video and seemed easy enough. The kit came with a vanos filter, larger o-ring, and a small o-ring. Replacing the large o-ring and filter is no big deal, however the small o-ring must be pried off (as it was also done in the video).
Unfortunately there is a white plastic collar that is also beneath the small o-ring and broke the same time the o-ring did. I have no idea how someone could remove the small o-ring without breaking this collar. Looking at parts schematics, the collar doesn't even appear in the diagrams. Now I don't know who to proceed. Anyone have experience with this? Thanks! |
05-26-2018, 09:31 PM | #2 |
Rep 1,483
Drives: 09 E91 328i & 07 E86 M
I can't remember exactly what that looks like, can you post photo of what you mean.
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter |
05-27-2018, 02:46 AM | #3 |
639
Rep 3,124
I seem to remember from the videos, you're not supposed that break that part.
I don't think it's available separately. A warning to others: I've changed mine a few times, and I think it's mostly a scam. The only time I've had any swarf was after breaking a Vanos exhaust hub tab. Only change it after you've had some sort of abnormality that will produce swarf, like breaking a tab.
mainsoda171.50 |
05-27-2018, 06:48 AM | #4 |
Rep 24
Thanks Guys! After going to the auto parts store and finding an identical collar for a power steering system then proceeding to break that too trying to get it on, they looked up a brand new Vanos bolt and some of the images show that collar as having a cut in it.
I don’t think it can go on without being split. Because of this, I just threw it back in the car with new o-rings, filter and split collar and so far so good. The 45 degree cut made it seem like I didn’t break it after all |
05-28-2018, 09:01 PM | #5 | |
Rep 150
05-29-2018, 03:46 PM | #6 |
639
Rep 3,124
swarf
swôrf/ noun: swarf fine chips or filings of stone, metal, or other material produced by a machining operation. "a curl of metal swarf" Oh, and my Dimple magnetic oil drain plug came out with a pretty full beard after the hub tab breakage.
