04-18-2017, 11:40 AM | #23 |
Rep 2,707
Nicely personalized.
04-24-2017, 01:26 PM | #30 |
Rep 912
05-28-2017, 12:00 AM | #33 |
Rep 202
Very cool, like the build a lot. I have the same car but with black interior. Curious on 3 things...
1) how much harsher is the ride compared to 18s? 2) what modifications did you have to get you to 233whp? 3) how did you get the key to remotely open the convertible top? |
05-31-2017, 07:35 PM | #34 | |
Rep 912
1) I did suspension at the same time, so its hard to tell you. But driving lower profile tires always harshen the "edged" and "imperfection" in the road because there is less rubber to dampen the initial hit. If you don't have suspension, dont get 19" wheels it wont look proportional. 2) Catless headers, Dinan exhaust, Dinan intake and Eurocharged tune. Even the dyno/tuner @ Eurocharged said the motor was strong to begin with though. 3) Programmed it myself. You could have someone do it for you or you could search the forum/google for more info. |
06-08-2017, 10:26 AM | #36 |
Rep 912
Eurocharged Canada recently they did a ZHP 330 with a tune and saw 230whp +/- 1hp (I can't remember the exact figure). I'm in the high range for sure, but not unreasonable. Motor was strong before the tune. Lucky I guess and a good tune.
08-24-2017, 01:55 PM | #37 |
Rep 912
First, borrowed some M550i E60 wheels from my dad. He had already wore the rears down and needed replacing. So I figured for fun, why not try them on? Right? (275/35/19 rears!) Then I made clouds!
I'm just gonna leave these here Oh....and this: https://youtu.be/Yaw-s6kg67g Tires after: |
08-24-2017, 02:13 PM | #38 | |
I plead the 5th.
527
Rep 1,519
BTW digging your build! Nice that you're doing your own thing and cool to see more roadsters with wings!
-Matt
3GFX722.50 |
05-02-2018, 03:03 PM | #40 |
Rep 912
So it's been a little while since I updated. I got sent some pics that have spurred me to fill in what's been going on.
Winter 2017/2018 - Wrapped in Glacial Frost - Z4 Sport seats installed - New windshield - New under windshield cowl - Tinted fogs - New badge vinyl (the blue is LeMans blue to match the brakes) - Custom headlights (black housing, upgraded lenses with etched Slovenian coat of arms, custom halos, and demon eye. BT controller and tinted signal light (hockey stick)) - Konig Ultraform 18" and Nankang NS2R track tire (not pictured, track duty only haha) |
Mirko182.00 |
05-02-2018, 05:49 PM | #41 |
Rep 11,669
It was great seeing you at Mosport on the weekend.
The car is completely transformed!!!
3GFX722.50 |
05-02-2018, 06:10 PM | #42 |
Rep 1,031
Agree .. pictures dont really show the color changing abilities of that wrap.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
3GFX722.50 |
05-03-2018, 10:01 AM | #43 | |
Rep 912
06-13-2019, 10:11 AM | #44 |
Rep 912
It has definitely been a while since I’ve posted any updates on the car. Let me tell you that the last few weeks have been a cluster of diagnosing things and figuring out minor problems here and there. But I’m happy to say that last weekend I was out on track with no issues, and surprisingly minimal heat soak. Very happy with my Z4.
So let me get you up to speed. Over the winter I purchased ESS Tuning’s last TS2 Kit. It’s a positive displacement Whipple (W100AX) charger with an ESS manifold and upgraded injectors. The key difference between TS1 and TS2 is the integration of a cooler into the manifold. A water pump circulates water to a front mount (setrab) cooler that then feeds to (laminova) cores within the manifold. The best way to summarize is that there are 3 cylindrical radiator type cores that have this water (coolant) fed through them to cool the air as it passes through the manifold. I was looking to supercharge for a while now and through countless hours of research both on this forum along with others and chatting with owners of SC systems I decided the TS2 was the best fit for me. As I said the kit included an air to water cooler that feeds right into the manifold which for now is the best option for me to supercharge on the track. Intake temps will always be an issue, but this seems like a reasonable solution. 11Tenths Racecraft installed the charger along with the other goodies. At the time of install we replaced the clutch and flywheel with a replacement stock unit (I should mention the car was at 165,000Kms on the stock clutch). I installed a steward high flow water pump. Which was a fun install because the bracket in front of the motor (front clip) completely blocks the removal of the pump so I had to practically remove the entire front clip of the car just to change it. We installed a CSF rad and Radium catch can kit. Obviously the goal was better cooling throughout. We also installed an RTD shifter and in my own time I installed an AEM X AFR and Boost gauge in the ashtray. Now onto the issues… Lets start with: Tune: 1st tune – DISA error and o2 sensor heat error (CEL) (disa is removed with this manifold) 2nd tune – o2 sensor error (CEL) 3rd tune – o2 sensor removed in tune (no-CEL) since I have no secondary O2s All good for now, gotta keep an eye out as I had one lean CEL which hasn’t resurfaced. The supercharge coolant setup: The ESS system included no reservoir for the cooling system. Essentially fill the hose best you can, run and refill. This was an issue since you cannot guarantee getting all the air out, nor is it easy to do since the hoses are insanely stiff. Luckily 11Tenths came up with a great solution. The TS2 kit came with a relocation kit for the E46 hydraulic steering. Since the Z4 has electric steering this reservoir wasn’t needed. 11Tenths fabricated some fittings for the reservoir was well as a bracket and it is now in line for the cooling system. This allows air to escape and me to monitor the coolant! Coolant leak: 1st leak - At first the SC cooler (setrab) was leaking. The hoses are very stiff so I suspect during install the fittings came loose. I tightened them and added an extra oring. Seems to be ok. 2nd leak – custom hose. The hose from the motor to the rad is custom made by ESS to clear the charger. It was rubbing against the front clip bracket so we ground that down to make room. Although the leak is gone, I’m currently driving around with a spare hose just to be safe for track/trips etc. Pulley/whipple oil leak: 1st- the supercharger was leaking oil from the pulley wheel. This is actually common since there is an overfill drain hole. In this setup the supercharger is on its side so the oil fill level isn’t quite the same. Luckily oil is a standard ford/gm part # so I grabbed some extra. The oil leak has since stopped, and the gea rtrain is still lubricated as per the oil fill window. 2nd – the pulley vibrated 2 of 4 bolts loose with only one holding it on. This was easy enough. Put in new bolts, locktite blue and they seem to be ok. Stressful though. Other stuff: Custom headlight halos stopped working after all the work was done. Turns out that a ground came loose but it took a while for me to trace that. It’s all fixed and working. RTD shifter: There was some slack when it was in between gears. The allen bolt for the Neutral area adjustment came loose. I re-centered as per instructions and tightened it down. Hasn’t been a problem. Track stuff: Went through my EBC red stuff pads again. They lasted 5 track days on the front. I’ve bitten the bullit and switched to PAGID RS29 on the front. I will let you know how they hold up. They are phenomenal feel and stopping power, but I hope they last longer as they were double to price of other pads. I had no choice as I was at the track and it was all the local performance shop had in stock for my front brake setup. I’ll come back to post my feelings on the supercharger at a later date as I’m only starting to really enjoy it now that all this stuff has been worked out. For now though, dyno results: Couldn’t have asked for a more linear power band. 306.9 RWHP – Rear wheel horsepower 293.1 RWTQ – Rear wheel torque (approx.: 361HP Crank (136hp over stock) (approx.: 345 LB/FT Crank (123hp over stock) https://youtu.be/SX0Uh2ZKtkE |
Steeler2430.00 |
