07-11-2016, 09:08 PM | #1 |
Rep 55
Track Day Temps
Hey guys, I got back from my first track day this past Saturday and during sessions I noticed my coolant temps getting as far as a couple of ticks before the 3/4 mark. Any cause for concern? Thinking of getting a SPAL fan setup and eventually a larger oil cooler as well. Any advice or tips/info are greatly appreciated. BTW, the track temps in Cali are always likely to be ~100 F around this time afaik
07-12-2016, 01:49 PM | #2 |
1821
Rep 5,337
The coolant temp is heavily buffered. If the needle moves AT ALL you need to be concerned.
Although 100ºF temps shouldn't give the car any trouble. When's the last time coolant was flushed? It should be on a 4 year flush schedule for street cars, 2 years for heavily tracked cars. How many miles on the car?
07-12-2016, 05:58 PM | #3 | |
Rep 758
Coolant flush for certain. Is the water pump the original? I'd check fault codes for water pump below speed regardless.........
Top Down 365
07-12-2016, 06:04 PM | #4 |
1821
Rep 5,337
Also, I don't remember seeing a coolant temp gauge on the car. Unless I'm smoking crack and don't know about it, I'm 100% certain there's no coolant gauge. Is this a secondary, aftermarket gauge you installed? If it is I take it back.
There's an OIL TEMP GAUGE, which on a super hot day, being driven the p*ss out of, it's not out of the realm of possibility for the oil temp to climb a little. I've seen as high as 260ºf, which is just a hair north of middle, on a day where ambient temp is as high as 116ºf and tarmac temp as measured by a infrared thermometer at 160ºf.
07-12-2016, 07:38 PM | #5 | |
Rep 758
Top Down 365
07-13-2016, 12:03 AM | #6 |
Rep 55
False alarm. I was looking at the oil temp gauge and it was reading at about 250* F lol. The track temp was well over 100*F and the car was being driven hard, so i'm not too worried. Any aftermarket oil cooling solutions for the z4m or are they not really needed?
07-13-2016, 08:35 AM | #7 |
Rep 2,138
Drives: Me
The ///M's oil temperature gauge, center of scale is 210'F.
On the track, once in a blue moon, with ambient temperatures around 98'F, I might hit 215'F, if I was really flogging it... If track temps are less less than 90'f, my oil temps are around 205'. |
07-13-2016, 09:03 AM | #8 | |
Rep 55
By what I have seen so far, 240-255*F is not out of line for the s54 on track. |
07-13-2016, 09:40 AM | #9 |
Rep 2,138
Drives: Me
In the summer, I normally hover around 200-205'F on the street. In the winter around 195'F.
It has been accepted practice for the last 15 or so years that you do not fill the oil to the max line on the dipstick on the S54. I also, yearly, pull the front bumper cover and clean my oil cooler and radiator. Almost a 1/4 cup of debris will come out of the oil cooler alone. Additionally, I do not run Castrol 10W60. I run Redline 15W50. The reasons have been posted here (on this board and others) before and I will not go into this in this thread. But running 15W50 also lowers my engine oil temperatures. It has other positive effects also. |
07-13-2016, 11:23 AM | #10 | |
707
Rep 7,850
+1 on that and the halfway point on the dipstick. |
07-13-2016, 06:40 PM | #11 | |
1821
Rep 5,337
I recall one of the suppliers that used to sell my old company transmission lubricants showing us that for every 20 degrees over 240 degrees in operating temp it effectively HALFS the usable life of oil based lubricants. The 10W-60 has at least 15,000 miles of life in them, so even if you're seeing 270 degrees regularly, if you change every 7,500 miles you're more than safe. 10W-60 doesn't vaporize until like 340 degrees I think. Anyway, given the annual change cycle as required on these engines, a few track days of over 250 degrees oil temp isn't really going to do ANY harm.
07-14-2016, 12:10 AM | #12 | |
Rep 55
Thank you for the info/assistance everyone |
07-15-2016, 07:43 AM | #13 |
Rep 5,329
i really hate not having a coolant temp gauge ...
we have a 2 stage light up setup... amber means... chill out, red means ... head gasket failure imminent LOL... but seriously I'm pleased to report I've never seen a coolant warning but i tell you with my blower i can heat up the oil quickly!!
08-04-2016, 09:37 AM | #14 |
Down Under!!
1624
Rep 4,296
I have a water temp gauge
but yeah my car sees track day temps in access of 40 degress and the oil temp gauge does shift to the right about 5-20 degrees, depending on how i am going and how the track is set up. Ive come to the realisation that 40 degrees OAT is probably enough, and anything over that is good beer drinking weather to talk about track, rather than actually being on it.
Powered by |
08-04-2016, 12:23 PM | #15 | |
Rep 1,923
I was there and it was 110 degrees. My oil temp stayed around 240.
08-04-2016, 06:35 PM | #16 |
Rep 55
08-04-2016, 06:40 PM | #17 | |
Rep 1,923
didnt think I need oil cooler so far. I have motorsport thermostat and oil bypass valve. seems like its enough for now...on hot weather I try to not use same oil for more than 3 track days. |
08-05-2016, 06:55 AM | #18 |
Down Under!!
1624
Rep 4,296
I am fabbing a secondary oil cooler behind the right fang, but only due to our extended elevated temps here in the sand box.
Powered by |
