01-09-2016, 03:53 AM | #45 | |
Rep 67
01-09-2016, 03:58 AM | #46 |
Rep 5,329
its horrific. lol.
but with my roadster it is probably just the right side of bearable, but in reality i love the noise!
01-09-2016, 04:07 AM | #47 |
Rep 67
01-09-2016, 11:20 AM | #48 |
Rep 2,784
If you want a set, let me know!
01-09-2016, 05:29 PM | #49 |
Rep 5,329
their u go op.... may not be many of these left tbh... .
01-13-2016, 07:25 AM | #51 |
Rep 5,329
thanks OP for sending me that discharge charge FREE of charge!! thats what i call forum spirit!! it replaced a really tired looking pieces in my engine bay and really adds towards the install looking as clean as possible :-) I really appreciate that btw, it seems the new silicone couplers ESS are supplying with these kits are superior to what was supplied with mine :-)
01-13-2016, 07:55 AM | #52 | |
Rep 67
01-13-2016, 09:52 AM | #53 |
Rep 5,329
hows the car running ?? has your new found power broken anything yet?? lol..... if it hasn't... its coming!!!
01-14-2016, 12:02 AM | #54 | |
Rep 67
My plan is to change the half shafts and engine mounts to make it strong enough to withstand the extra power. Did you face any issues with yours? Any suggestions? |
01-14-2016, 10:49 AM | #55 |
Rep 5,329
to be honest not much really, i maintain to a really high standard and after recently having a tight clearance on the inlet side, learned to do my own valve clearances, no where near as bad as the mystique behind the illusive clearances... really simple if a-little time consuming.
those half shafts are a good security and lower service intervals , plug changes, just be ON maintenance items. Engine mounts are a MUST if you can afford to do it now.
01-14-2016, 10:50 AM | #56 | |
Rep 2,176
Unless of course you plan on launching the car with wrinkle slicks at the dragstrip lol . |
01-14-2016, 01:26 PM | #57 | |
Rep 5,329
their has been around 5 z4ms thats are s/c with the half shafts fail. All on street tyres ... all supercharged... just something to consider but not a must do right now job.
01-14-2016, 02:35 PM | #58 | ||
Rep 2,176
George |
01-15-2016, 01:10 AM | #59 | |
Rep 5,329
fair enough agree with this...
01-15-2016, 09:55 PM | #60 |
Down Under!!
1654
Rep 4,318
man, what a nice read, the vortex is really nice and sounds like its got plenty of power on tap mate
Nicely done.
Powered by |
01-16-2016, 03:38 AM | #61 |
Rep 67
Thanks guys for sharing your thoughts....
Engine mounts is definately a must with so much power, I can feel the engine moving a lot when accelerating. Half shafts will be done on a later stage (I will try to avoid spinning the car....lol) my budged is getting low at the moment and I have to install bigger brakes and oil catch can !!! |
01-16-2016, 03:40 AM | #62 |
Rep 67
03-08-2016, 10:26 PM | #63 |
Rep 77
Hey out of curiosity, why the SS v1 stepped headers and the modification to make them work? Also, I had read somewhere (I'd have to dig it up) that stepped headers weren't as good for S/C....your dyno results clearly disagree...I was looking at CSL euro headers and euro section 1....I wonder how the results would compare.
03-10-2016, 01:27 AM | #64 | |
Rep 67
At the time of SC installation I was advised from ESS to change back to OEM Euro header as they have noticed in some cars drivability issues. They assured me though that there is no safety issue!! So decided as it’s not an easy task to swap back to OEM to give it a try with the stepped ones and incase of any issues then to change over. Probably I was lucky enough and things went smooth...... |
03-10-2016, 02:49 AM | #65 |
Rep 5,329
hows it running ??? update needed really.
03-10-2016, 10:31 AM | #66 | |
Rep 2,784
The car will run fine with stepped headers (I have two supercharged Z4M's, both running two different kinds of stepped headers). ESS will tell you otherwise, because ESS and Evolve don't get along, and Evolve sells Supersprint products (which used to be the only stepped headers in town).
