11-30-2014, 02:34 PM | #1 |
Rep 335
Front M vs Non-M
The front suspension of the M and non-M are essentially the same aren't they? Based on the e46? So any wheel fitment used on an M would work for a non-M, right? I'm trying to decide proper wheel offsets and don't want rubbing for 18s. Car will be on Coilovers. So, I'm thinking the 235/40-18 8.5 et 35. Seems like the safest yet still aggressive option.
11-30-2014, 03:45 PM | #2 | |
Rep 1,135
11-30-2014, 10:39 PM | #4 | |
Rep 12,635
Garage List E86 Z4 M [10.00]
12-01-2014, 06:21 PM | #5 | |
I plead the 5th.
529
Rep 1,519
Interesting to see the Z4 and Z4M have differed OE tire profiles. Non-M is 225/40 & 255/35 while M is 225/45 & 255/40.
-Matt
12-01-2014, 07:09 PM | #6 |
Rep 12,635
That's exactly where it was rubbing, where fender and bumper meet.
12-01-2014, 08:02 PM | #7 |
I plead the 5th.
529
Rep 1,519
@sdcoupe - How low do you plan on dropping the car? ^^^ This is where I had some rubbing issues as well but your desired ride height is going to have an effect on things as well.
-Matt
12-01-2014, 08:05 PM | #8 | |
Rep 758
3.0si Roadster with M Sport suspension. |
12-05-2014, 06:56 AM | #9 |
Rep 441
The front suspension is very different between the m and non m...the m uses e36 bottom mounts, the non m uses e46 mounts...for clearance purposes they won't be drastically different though
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
12-05-2014, 09:32 AM | #10 | |
Rep 335
01-05-2015, 11:07 PM | #11 |
Rep 335
I just had mounted 235/40-18 front on new Apex PS-7 8.5' rims with Michelin Pilot Super Sports with 35 offset. No rubbing! Rears are 265/35-18 on a 9.5' rim with 43 offset. Again, no rubbing! Very stoked. It looks great. Need to put the coilover suspension on now and remove the fender gap.
