05-29-2014, 08:22 AM | #1 |
Why so serious?
146
Rep 743
REQUEST: E85 SMG ECU Diagram
As the title states,
I am looking for the E85 SMG ECU Diagram. Please and thank you EDIT: I am experiencing the P0700 code Last edited by SwissArmy; 05-30-2014 at 09:29 AM.. |
05-30-2014, 09:29 AM | #3 | |
Why so serious?
146
Rep 743
I was on the E46 M3 board, and someone said that we don't have a trans oil temp sensor. The z4 SMG is not the SMG2 but a different H-SMG similar to the SSG. I am getting the P0700 code. I am going to get my local indy to scan the codes and see what Transmission issue I am experiencing. Probably need a new battery, and a new fluid change. Though, I did one last year...hmm |
06-13-2014, 03:44 PM | #4 |
Rep 222
Curious as to your present situation.
I BELIEVE the P0700 code on the SMG may indicate failure of the shift mechanism but doesn't specify which component. My car indicated a complete failure a couple years ago which, after further analysis, was cured with a pump replacement. My problem began as intermittent no-shift when under hard use and progressed to failure under normal use. Obviously, low voltage caused by alternator/battery/load issues would play havoc with shifting. |
