03-11-2014, 09:38 PM | #1 |
Rep 226
ESS direct flash, Wheel bolts, Stubby
ESS Direct Flash: $500 (Note: Useless unless you know how to hack it because it's keyed to VIN) Stubby antenna, 4": $25 (see pic below) Wheel bolts for 3mm wheel spacer, p/n TWH995128B, set of 20, $5k commuter miles: $30 (see pic below) Wheel bolts for 5-8mm wheel spacer, p/n TWH995132B, set of 20, never used: $40 (see pic below) SOLD Z4 coupe car cover: $75 (see pics below) SOLD MRTM aluminum pedals: $50 (see pic below) SOLD Stock kidney grilles: $35 (see pic below) SOLD RPI skid plates, never used: $45 (see pic below -coming) ^^^ 4" stubby antenna w/adapter stud for Z4 ^^^ ^^^ Bolts for 3mm spacer (set of 20) ^^^ ^^^ Bolt for 3mm spacer, thread length around 25mm ^^^ ^^^ Bolts for 5-8mm spacer (set of 20) ^^^ ^^^ Bolt for 5-8mm spacer, thread length around 28.4mm ^^^
Mods: Alex tune, mod'd X-pipe, MPEv2, MS intake 2, ESS UDP, MFactory CFDSv3, RE SSK, Monoball bearings, SSFBs, TCKR DA susp, PFv3 rotors, AMX seats, Voltphreaks batt.
For sale: Valvetronic X-pipe w/HFCs, BW Race muffler, Test pipes, 19" Vorsteiner VFF103 rims, front thrust arms, stock muffler Last edited by cmichaelo; 03-25-2014 at 11:20 AM.. Reason: Additional item, bolts |
03-12-2014, 12:31 AM | #2 |
Rep 19
I will take the car cover. Please email g_sasha@walla.com to make the deal
Quality antenna? PMd you too. Last edited by drsasha; 03-12-2014 at 12:38 AM.. |
03-12-2014, 06:16 AM | #3 |
Rep 1
Put me as second in line on the car cover if the deal does not work out. You can email me at warrenskaggs@hotmail.com
03-12-2014, 08:11 AM | #5 |
Rep 226
There's a person ahead of all three of you on both the car cover and the pedals. I'll let you know if it doesn't work out. I'm not shipping abroad.
The antenna has surprisingly good reception. I couldn't even tell the difference from the stock antenna. I have all the hardware for the pedals.
For sale: Valvetronic X-pipe w/HFCs, BW Race muffler, Test pipes, 19" Vorsteiner VFF103 rims, front thrust arms, stock muffler |
