01-01-2014, 02:02 PM | #23 |
Rep 880
01-01-2014, 06:10 PM | #24 |
Rep 67
01-01-2014, 11:58 PM | #25 | |
639
Rep 3,124
I just took a look at the APRs on their web site. Looks like there may be a lot of flex in the panel that mounts them to the car.
01-02-2014, 10:34 AM | #26 |
Not a New Member
94
Rep 925
all weights are in lbs...
battery (80Ah AGM) = 51.00 exhaust section 2 (USA) = 16.81 rear shock = 4.09 rear spring = 5.19 front sway bar = 14.08 front sway link = 0.77 / ea. rear sway bar = 6.84 rear sway link = 0.18 / ea. flywheel = 25.04 pressure plate = 11.55 clutch disc = 2.39 ///m hood = 24.2 stock side skirt = 4.53 / ea. aero side skirt = 5.47 / ea. stock ///m front cover = 11.90 aero front cover = 11.88 stock ///m rear cover = 11.91 xenon headlamp (minus bulbs and cntl units) = 5.65 / ea rear LCI taillamp = 1.72 / ea. front fender = 10.01 / ea. headliner = 9.90 long block (w/ crank, rods, pistons, flywheel, complete head, vanos, pan, valve cover, water pump, and t-stat) = 322.30 transmission = 97.90 differential = 81.62 steering rack = 14.61 front subframe = 16.72 front spindle = 9.46 / ea. front lower cntl arm = 5.83 / ea. rear subframe = 30.29 rear knuckle = 22.09 / ea. rear lower cntl arm = 5.52 / ea. rear trailing arm = 2.79 / ea. gas tank = 19.80 fuel pump = 2.00 fuel filter = 0.84
01-02-2014, 11:46 AM | #27 |
Not a New Member
94
Rep 925
complete driveshaft assy = 18.06
01-02-2014, 03:16 PM | #28 |
Not a New Member
94
Rep 925
rear hatch interior panels (all) = 4.31
dash (bare) = 19.76 aluminum trim (all) = 4.50 wood trim (all) = 4.24 carbon leather trim (all) = 3.88 center console (bare) = 3.41 rear console "cubby" = 2.71 carpet (cabin) = 24.11 carpet (trunk) = 4.67 rear theft blind (coupe only) = 7.70 trunk paneling (all) = 6.80 bulkhead paneling (behind seats, all) = 8.32
01-02-2014, 03:20 PM | #29 |
Not a New Member
94
Rep 925
all in-cabin interior sound deadening panels = 8.03
(dash, trans tunnel, roof, doors, rear wheels)
01-02-2014, 04:54 PM | #30 |
Rep 11,667
@v3.2mc Great data!!
........ where are you finding all this info?
01-02-2014, 05:26 PM | #31 |
Not a New Member
94
Rep 925
i have a registered copy of ETK.
if you have a copy, you may be able to see this data for yourself by selecting the "i" on the far left of the part description frame. weight is shown in kilos...
01-02-2014, 05:41 PM | #32 |
Rep 11,667
Great!!!!!!! Thanks
01-02-2014, 08:48 PM | #34 |
Rep 11,667
^ would love to know that as well.
Ideal pieces to be done in composite. Reducing mass at both extremities would be fantastic!
01-02-2014, 10:36 PM | #35 |
Not a New Member
94
Rep 925
front reinforcement bar = 9.35
front re*bar deformation frame = 5.62 / ea. rear reinforcement bar = 23.54 rear re*bar shock = 5.63 / ea.
01-03-2014, 09:02 AM | #37 |
Not a New Member
94
Rep 925
e86 body-in-white = 586.30
--- e85 body-in-white = 585.20 --- my thought on the similarity between the weights of the e85 and the e86 is that the diagram for the e85 is so terrible there *must* be detail missing that would provide a hint as to why it is nearly as heavy as the coupe.
01-03-2014, 09:13 AM | #38 |
///M-fanatic
196
Rep 3,885
lol not to sound like a douche, but that E85 diagram is as if it were drawn up on a Monday or a Friday of the workweek
Definitely not on par with the E86's diagram heheh |
01-03-2014, 09:23 AM | #39 |
Not a New Member
94
Rep 925
... during octoberfest maybe?
01-03-2014, 12:59 PM | #40 |
Not a New Member
94
Rep 925
main wiring harness = 47.96
door wiring harness = 0.77 / ea. front headlamp harness = 1.98 / ea. rear lamp harness (all) = 4.84 seat harness = 0.48 / ea. battery sbk = 1.56 pos batt cable = 2.42 neg batt cable = 0.44 headlamp wash pump = 0.37 headlamp wash nozzle = 0.35 / ea. headlamp wash hoses (all) = 0.81 a-pillar cover = 0.48 / ea. b-pillar cover = 0.31 / ea. c-pillar cover = 0.37 / ea. floormats (both) = 3.52
01-03-2014, 01:40 PM | #41 | |
40
Rep 1,481
Found it. Front fenders weighed in at 9.9lbs. on a premium scale. Last edited by Twisted Six; 01-03-2014 at 01:45 PM.. |
AriuSen792.00 |
12-03-2018, 07:08 PM | #42 |
Down Under!!
1654
Rep 4,318
aluminium roof 38 lbs?
pretty sure its not alu and that seems awfully heavy?? is that right?
Powered by |
12-04-2018, 09:15 PM | #43 |
Rep 929
This list was put together a long long time ago, but numbers were taken from other threads on this forum. If anyone has changes/updates, easy to to.
Andre - 2J into a Z4 Coupe!
12-05-2018, 08:22 AM | #44 |
Down Under!!
1654
Rep 4,318
Yeah its NOT 38 Lbs... NO WAY!!
No its steel. weighed mine today, its 9 KGS. (mine was 9.0, as it had been painted black) so total weight loss is 7KGS. plus or minus a few grams. Still a pretty darn good weight savings for up top. White dot = fridge magnet.. def steel
Powered by Last edited by Vanne; 12-05-2018 at 10:35 AM.. |
