      11-17-2013, 02:40 AM   #1123
Beedub
tom...... hold fire... found a company that will machine us a complete 8 rib setup!!! ones been done already here!! looks good, every pulley CNC cut...
wow wow wow wow..... heres a pic of a 15lb boost 8 rib setup they did for an ess vt-500, still using v3si!!!!
New bespoke pulleys to achieve c. 15psi boost. These are now for an 8-rib belt, rather than the old 6-rib one, which should help prevent slipping at high rpm...
im going to call them about knocking me up a 10lbs setup.. tom youve inspired me, its time to leave Ess behind and go forth with our quest for power, the hard bits are in place now, but i do think the cooler needs to be upgraded, as will the oil cooler, radiator!!
just look at those pulleys!! lovely lovely!!
      11-17-2013, 10:18 AM   #1124
ZStig
instagram 997turbotom
296
Drives: Alpina XB7
Nothing wrong with ESS, I love them. I'm just out of the warranty period, and would like to pursue my own path.
forget 10psi. go for 12 and be happy for years to come. The stock engine can hold 520rwhp safely according to JAWS.
      11-17-2013, 12:31 PM   #1125
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Holy hell... how do you guys keep traction? I have a hard time on 265 Pilot SS and 6 psi in the summer.
      11-17-2013, 03:28 PM   #1126
ZStig
296
Drives: Alpina XB7
sticky tires and a patient foot
      11-17-2013, 03:30 PM   #1127
Beedub
I definitely don't love them they are ok .... Strictly ok IMO.... this 8 rib setup is something ill try and come back once the car son the road again next year, the winter has set in over here now, this is my part hoard time but sadly money is pretty tight right now :-( however i stand to do pretty well from my CSL sale when it happens and will be looking to add a touch more boost :-)
      11-18-2013, 08:39 AM   #1128
ZStig
296
Drives: Alpina XB7
8 rib is great for big boost. For 10-12psi, i think we can get away with a custom big 6 rib crank pulley
      11-21-2013, 08:58 PM   #1129
ZStig
296
Drives: Alpina XB7
I wish someone here could draw up a bigger crank pulley in CAD software..
      11-22-2013, 02:08 AM   #1130
GuidoK
#buildnotbought
GuidoK's Avatar
12620
Drives: Z4 3.0i ESS TS2+
Did you try local machine shops?
The pulley in itself is pretty simple. The real trick is to find a machine shop that can turn the pk rib profile on a lathe. I think it's a 40deg profile, so you can't make that with an ordinary lathe bit. (having a CAD model doesn't change that)
Exact specs for the PK profile are in/according to DIN 7867.
On the other hand: if that ESS pulley is exactly the specs you want (or if you can order that made to order) I'd go for that for $500.
      11-22-2013, 12:44 PM   #1131
ZStig
296
Drives: Alpina XB7
great tips thanks!
One of my metal lines going to the oil cooler has rubbed long enough on the wheel liner, to rub off enough to develop a small pin-hole size leak. what the fuck. I patched it up with rubber tape and a clamp. hope its not a high pressure area. Will see how much those parts cost to replace, and next time make a bracket to push them away from the wheel liner
      11-22-2013, 01:31 PM   #1132
Beedub
31,000 views....
impressive!!
      11-22-2013, 02:25 PM   #1133
GuidoK
#buildnotbought
GuidoK's Avatar
12620
Originally Posted by ZStig View Post
great tips thanks!
Be sure that it doesnt turn into a leak that drops the oil pressure.
No oil pressure=almost instant engine seize when under load.
(but then there is a considerable leak, or you could run out of oil of course. Small leaks can turn into bigger leaks because the oil is pressurized)
If the lines are expensive (of course they are....) you could try to weld them or braze them (both require an experienced welder), or you could put in a pipe fitting (clamp type). New lines is the best solution of course.
It is the high pressure area because they are the outlet at the filter housing and the filter is the first thing in line after the oil pump (at least: that's the normal way in an engine).
      11-22-2013, 03:44 PM   #1134
ZStig
296
Drives: Alpina XB7
good tips. I think its a low pressure area. I let the car idle, and revved it to 4000rpm, and no leaks. Anyone know the part number to this line? You can see the clamp on it near the wheel liner
      11-22-2013, 03:57 PM   #1135
ZStig
296
Drives: Alpina XB7
I think its the "oil tube" 17227836831
$225. Gonna see if a welder can repair it instead first
      11-23-2013, 03:01 AM   #1136
Beedub
tom , how does a thin plastic liner rub through a metal line??? are you sure your wide tyres arent pushing the liner against this????
      11-23-2013, 03:20 PM   #1137
ZStig
296
Drives: Alpina XB7
I think the tires are putting pressure on the liner, and pushing into the lines
      11-23-2013, 03:23 PM   #1138
ZStig
296
Drives: Alpina XB7
So today I had my car towed again..
I tried to start it, clicked 2 times. Tried again and it started up a few minutes later. While driving 100 yards, the engine RPM dropped to 0 and the car stalled. I was sure that I seized my engine due to the oil leak. Checked the pipe, no leaks. Checked the oil, normal level.
Called a tow truck to tow to the dealership, already in my head thinking about the cost of a new engine and about getting rid of the fucking thing.
A mechanic friend suggested it could be the alternator, combined with my tiny 11lbs battery. Sure enough, I was able to jump start the car and it settled into a nice idle. So the engine is fine, thank God. I do need a new alternator though, based on what I've experienced, correct me if I'm wrong.
Whats the best source? 150 amps? is there a lightweight version available?
Ecs tuning has a reconditioned one for $530, Ebay has one for $300 http://www.ebay.com/itm/BRAND-NEW-GE...55c15b&vxp=mtr
      11-23-2013, 05:37 PM   #1139
ZStig
296
Drives: Alpina XB7
Breakdowns will continue until morale improves
      11-23-2013, 05:39 PM   #1140
ZStig
296
Drives: Alpina XB7
      11-27-2013, 07:45 PM   #1141
ZStig
296
Drives: Alpina XB7
New alternator is in, car is back on the road. Had to loosen an engine mount, and jack up the engine a few inches to get the bolt holding the alternator in. Supercharger had to come out too with its bracket
      12-08-2013, 07:51 PM   #1142
ZStig
296
Drives: Alpina XB7
wiped down the interior, washed the outside, wiped down the engine bay. Went to a 600+ people custom car show. Walked around, only saw a handful of BMWs, decided to upgrade my ticket and enter my car. BOOM!
      12-09-2013, 04:02 AM   #1143
Tiago
Tiago's Avatar
25
Drives: BMW
Wow. That would be nice upgrade. Do you know if they had to move parts on the e46 to clear the 8 rib pulleys?
In my other post i said vac mls 0.7. It is a VAC Motorsport steel multilayer gasket 0.7 above oem gasket to raise a the engine head and decrease a tad the compression ratio. I know that it is pretty common on other engines to run safe +15lbs just with a higher head gasket.
Congrats for the award.
      12-09-2013, 08:29 AM   #1144
ZStig
296
Drives: Alpina XB7
Very cool idea in regards to the headgasket.
As per your question about boost, my boost isn't maxing out because i'm on a custom, 2.87" pulley which is coated to not slip, but still slips. Too small, but i got a really good bump in midrange boost
Originally, i had a less aggressive pulley setup than Bdubb, so my max of 7psi was correct for the sizes. Measure your crank and supercharger pulleys and compare them to the chart i posted before
