03-18-2013, 10:18 AM | #23 |
Hug the road... Carpe Asphalt
106
Rep 722
Thanks! I stopped pulling when it didn't want to come off. I will try again as shown in the link.
2007 BMW ///M Coupe
03-18-2013, 10:35 AM | #24 |
Rep 12,635
Garage List E86 Z4 M [10.00]
F15 X5 xDrive35i [9.17] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.53] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [8.93] |
By the way, this reminds me. I brought new bumper support brackets for both left and right side since the bumper was sagging a little. Upon installing the new ones, I could not for the life of me get the bumper to snap back in. The 2 outer most tabs would snap in but never the middle one. I even resorted to shaving off a micro layer off the tabs with a razor blade but still no dice.
I then pulled out the flash light and took a close look at the bumper brackets. I couldn't compare it to the old one because by then I had already broken them into a million pieces BUT I noticed the new brackets have these nubs inside that block the bumper from snapping back in. I don't know if this is a new design but it basically required me to pull out the dremel and create 2 new slots in the bumper to clip in. The bumper already has 1 slot... Using the Mr. Rogers's pics, the left circle shows where the existing slot is. The 2 to the right were where I had to create new ones. |
03-18-2013, 10:50 AM | #25 |
Not a New Member
94
Rep 925
^ +1
i had the same issue when going to the aero cover on the 3.0si... fixed in 5 sec with a drill and a spiral cut bit.
03-18-2013, 11:08 AM | #26 |
Rep 12,635
Unfortunately it's been so long I had the normal bumper I couldn't recall if the 3.0si bumper had those grooves cut in. Whack!
03-24-2013, 08:19 PM | #27 |
Rep 16
M coupe bumper removal
Thanks for the this thread on bumper removal. I'm in the process of removing my coupes bumper and have of couple of questions before I continue with the removal. First under the lower edge of the bumper I removed a total of four 8mm bolts which are located on the underside of the fangs, two on each side. I also removed three screws located between the fangs. Are these the correct and screws/bolts that you are referring to? Also I attempted to pull off the bumper by the headlight with a good amount of force and it did not budge. Are there any tricks that might help me get the bumper separated from the fender. I did grab the bumper below the clip that holds the two together. Should I pull forward, down or out to get them to separate? How about carefully prying the two apart with a screwdriver?
03-24-2013, 10:21 PM | #28 | |
Rep 12,635
03-24-2013, 10:57 PM | #29 | |
106
Rep 722
2007 BMW ///M Coupe
03-25-2013, 08:02 AM | #30 | |
Rep 16
03-25-2013, 08:04 AM | #31 | |
Rep 12,635
03-25-2013, 08:38 AM | #32 |
Rep 16
Yes I believe all the attaching hardware is removed. I just want to verify that the lower attaching points consist of 4 8mm bolts and 3 philphs head screws. I will give it another try
pulling away from the fender in a horizontal fashion while wiggling. |
06-09-2013, 05:20 PM | #34 | |
Rep 81
08-26-2013, 12:21 AM | #37 | |
Rep 13
Yes I can see this pic, but not the pics in the very first post. They look like broken links to me. Thanks rsk |
08-26-2013, 12:28 AM | #38 |
639
Rep 3,124
Hmmm. Very odd.
Well, I posted that pic because that's the only hard part. Get your fingers in there and yank 'till it hurts. The rest should be evident without pics.
08-26-2013, 05:06 AM | #39 |
Rep 11,667
Actually that pic leads to breaking the clip if you aren't carful.
The clip extends down where he has it gripped. Grip it lower & also use a plastics trim removal tool. It needs to pry down & out at the same time.
09-03-2013, 10:16 AM | #40 | |
Rep 2
09-03-2013, 06:12 PM | #41 |
Rep 1,034
While you do have to remove the bumper to get to the headlight, your question don't really apply to this thread.
You might be able to, with the headlight removed it makes it easy to take off the back cover and poke around but the lens/glass/whatever is sealed to the housing.
07-09-2014, 04:18 PM | #42 |
Rep 1,546
Well, here's to another bump of this thread. lol Wish I had found it before removal...might've saved the clips. BUT now I have new ones aaannnnddddd.....
Getting the old, broken piece out of the fender itself. I can't figure it out. Any help is much appreciated. Once that's out, I can get the new ones in and that's one less mod from the "to be done" file and moved to the "done look how awesome it is" file haha SIDE NOTE WHILE I HAVE YOUR ATTENTION lol Those who have deleted the headlight washers. where did you clamp/close/whatever the fluid hose so the one that run along inside the bumper isn't there? there's a better way to formulate that question, but it's going on midnight lol cheers
07-09-2014, 06:12 PM | #43 |
Rep 11,667
Not sure about the first one...
Re the hose delete. I just used a short 2" piece of hose and used a plug You could also do a loop back with a T fitting
07-10-2014, 04:06 PM | #44 |
Rep 1,546
And that's why I ask! lol I never think of clever little things like that!
As for the broken clips....just gotta pry em out. I used a small 7-level flat head screwdriver (the next size bigger than eyeglass repair ones) and after some strong finagling I got both of them out. the screwdriver however didn't make it. Unless I plan on using screws at around a 30 degree angle lol
