08-05-2013, 11:45 AM | #925 |
instagram 997turbotom
286
Rep 7,377
oh, and I'm going to hide the meth injection kit by using the windshield washer tank as the reservoir, and hiding the pump inside the bumper. Also plan to get it running on concentrated windshield washer fluid which is 30% methanol, and cheap enough to run daily. I guess within the next 3 weeks or so
08-05-2013, 01:01 PM | #926 | |
enthusiast
48
Rep 1,695
08-05-2013, 05:20 PM | #928 |
286
Rep 7,377
Probably a local dyno. I want something custom, not an off-the-shelf tune.
08-05-2013, 07:38 PM | #929 | |
Rep 2,782
08-05-2013, 07:52 PM | #930 |
286
Rep 7,377
Very hard to find something rated below -20* which is around 30% meth content, especially in Florida
08-05-2013, 10:29 PM | #931 |
286
Rep 7,377
Here's what my cutouts sounds with no cats, at partial throttle. They're now blocked off though, as they're for sale.
08-06-2013, 08:06 PM | #932 |
286
Rep 7,377
very odd, apparently my "old" belt was a 6pk2300. My ESS parts list shows it using a 6pk2315 so that's what I put in. Logic would say that this is a 15mm longer belt right?
I did a bunch of pulls and I'm getting a clean 7 to 8psi in 2nd gear at 7900rpm, but only hitting a max of 6psi on top of third gear... Slow boost leak, belt slip, or the rubber around the fittings on the air lines going to the boost gauge are old and maybe leaking there. The new Continental Contitech 6pk2315 doesn't feel any tighter either. I think I was seeing similar boost numbers on the old no-name belt today actually.. ugh.....
08-06-2013, 11:33 PM | #933 | |
enthusiast
48
Rep 1,695
08-07-2013, 06:58 AM | #934 |
Rep 5,329
When I get home ill check the belt on my car ....
08-07-2013, 09:01 AM | #935 |
Rep 5,329
08-07-2013, 09:01 PM | #936 |
286
Rep 7,377
5mm smaller than mine
girls probably won't notice I'm gonna double check my pulley sizes to make sure everything is correct, these recent vt2-525 threads are scaring me. I think my AEM meth kit's pump AND controller are dead. I'll have a shop confirm it. for fucks sake, I have only used it for a few days in the last 2 years, and already replaced the controller box once. Hope it was less than 1 year ago, and under warranty. Aem says they'll give me a discount on a replacement if over 1 year
08-07-2013, 09:31 PM | #937 |
286
Rep 7,377
Finally some luck, I have 3 weeks of warranty left on AEM's meth controller box, I'll get a replacement free of charge. The pump is only like $67.
I'll be cleaning up my ghetto install too.
08-07-2013, 09:38 PM | #938 | |
enthusiast
48
Rep 1,695
08-07-2013, 11:26 PM | #939 | |
Rep 33
-reduce the pulley on the compressor or increase the lower pulley. ... maybe you had posted/installed the belt correct with a wrong low puleghia.
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
08-10-2013, 06:44 PM | #941 |
286
Rep 7,377
Ok, I checked my measurements, and I have a 3.33" pulley (edge to edge since the ribs come up to same level), and 130mm crank pulley.
I think my hydraulic belt tensioner is tight enough, but my belt should be 5-10mm shorter to that there's less slack. Am I correct in assuming that a 2315 belt is exactly 5mm longer than a 2310 belt? Either way, I'm ordering a 141mm Jaws crank pulley soon , so I'll need a different belt
08-10-2013, 07:36 PM | #942 |
Rep 892
That will take you to exactly 570 spec (impeller speed wise; 48000rpm).
08-11-2013, 12:18 AM | #943 |
286
Rep 7,377
hope so!
08-11-2013, 09:34 PM | #944 |
286
Rep 7,377
I'm using Vortech's V-3 calculator, using engine speed of 8000. Are my numbers off? Honestly, I'm not sure what my peak boost is right now. I'm hitting 8 in second, but only 6.5 in 3rd...
08-12-2013, 09:50 AM | #946 | |
286
Rep 7,377
